mamun
Rep Power: 0 ![]() |
i'm facing problem in defining user defined function..
fluent 6.3 shows the following lines. " Opening library "libudf"... Error: open_udf_library: The system cannot find the path specified. " can anyone help me how to define the "user define functions" ???? ![]() u can send suggestion to " mamun.name06@yahoo.com " |
Laurent B
Rep Power: 17 ![]() |
Make sure that the UDF source file is in the same directory that contains your case and data files.
sanjay pawar
I alsp hav the same error.
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. There are some solutions (some pervious post) but no one specified the opertaing system. how to solve this problem with ANSYS 12.1 and windows 7 operating system. thanking You, |
Laurent B
Can post your udf file ?
MPI problem with fluent | aryanet | FLUENT | 17 | October 30, 2017 21:04 |
2D Heat Transfer problem in Fluent 6.3 please help | Damian | FLUENT | 4 | August 11, 2008 08:48 |
another 2D Heat Transfer problem in Fluent 6.3 | Damian | FLUENT | 6 | August 2, 2008 00:20 |
Problem about Fluent on Linux | hbinma | FLUENT | 3 | July 6, 2008 10:49 |
Problem using parallel Fluent | Gustavo | FLUENT | 0 | June 27, 2004 23:12 |
