Parallel
Old   September 28, 2011, 22:28
Default Parallel
Jack cosby
3DmaniacSLDWRKS is on a distinguished road
Can someone please tell me if it is NECESSARY to parallelize UDF codes if you are using a cluster to run your case??
My problem is that my case and UDF code run flawlessly on my desktop but as soon as I run the case on our computing center everything falls apart and I get very bad results.
Thanks
Any input is appreciated.
3DmaniacSLDWRKS is offline   Reply With Quote
Old   September 29, 2011, 15:59
Mohammad
m2montazari is on a distinguished road
hi,
it depends. do you compile your udf or interpret it? does it return any errors when reading the case on cluster or when reading C file? what is the DEFINE macro you used?
make the problem more clear.
yours,
mohammad
m2montazari is offline   Reply With Quote
Old   September 29, 2011, 18:39
Jack cosby
Thanks for the quick response,
No I dont have any problems reading the case and data files or the UDFs, but the results that I get are totally different( AND WRONG) from what I get on my desktop (WHICH ARE MOST DEFINITELY CORRECT).
macros that I use include execute at end, CG-motion, define-geometry, define-profile.
Can you explain to me what exactly you mean when you say it depends?
Thanks.
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
Cumulative continuity error large in parallel simulations xiao OpenFOAM 3 March 7, 2011 04:13
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
