Problem with compiling the UDF
Old   November 27, 2011, 15:10
Default Problem with compiling the UDF
raghu mohan is on a distinguished road
I followed the steps posted by amir here:
http://www.cfd-online.com/Forums/blo...fluent-vc.html
to compile udf. I have fluent 6.3.26 and MSVC++ 2008 express (which has visual studio 9.0, which consists of INCLUDE and LIB folder).
when I compile UDF fluent gives these commands:
Deleted old libudf\ntx86\3d\libudf.dll
1 file(s) copied.
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\3d\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\3d")()
Done.
When I load UDF I get these commands:
"c:/users/raghu mohan reddy/desktop/gambit tut"
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
The log file in the libudf file created shows this:
NMAKE : U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin\cl.EXE"' : return code '0xc0000135'
Stop.
Please help me in this issue
Thank You,
Raghu
raghu mohan is offline   Reply With Quote
Old   November 28, 2011, 05:53
Josy
Josyula is on a distinguished road
Raghu,
If you are using a 64 bit machine,
(a) download and install Microsoft Windows SDK v.7.1
(b) set the FLUENT environment variables
(c) open Windows SDK v.7.1 command prompt and type 'fluent'. You'll get the FLUENT launcher.
Try compiling now and see.
Josyula is offline   Reply With Quote
Old   November 29, 2011, 22:04
Thank You very much for your suggestion.
With the help of first two steps (a,b) itself the compiling and loading worked out well. I just copied one of the libraries necessary for compiling from SDK library to VS10 library.
Old   November 29, 2011, 23:15
I am posting how the above problm got solved here (May be a solution for 64-bit machine users only):
Actually I figured out VC++2008 which I was using was not compiling even as simple program in my PC, So I installed the VS2010 and ran a simple program and it was compiling and running good.
Then I changed the system variables as suggested by the Amir's link (I gave in 1st post).
Even though I was suffering with compatability issues bcoz Fluent I installed has Windows Xp compatability mode ON. I turned it OFF. (Error in Fluent:'IDB' is illegal extension for PDB file)
Then came another Error: " LINK1104: cannot open file 'kernel32.lib' " . I just copied this library from Program Files (X86)--->MS SDKs---->Windows----->v7.0A--->Lib-->Kernel32 and pasted in MSVS10.0-->VC-->lib
That's it done. Thanks for reading.
Thank You,
Raghu
Old   December 9, 2011, 01:23
Default udf
kabilan.B
kabilan is on a distinguished road
hai mr.ragu
i have same problem while compile my udf.
actually i m using win 7 64bit.
could u pls send me microsoft windows sdk v.7.1?
(hareesh.aero@gmail.com)
very thanks......
also one doubt, for my dynamic mesh problem i need udf,for compiling shall i need both visual studio c++ and microsoft windows sdk v.7.1?
thanks
kabilan is offline   Reply With Quote
Old   December 15, 2011, 23:03
hi,
Sorry for the late reply. Are you done with the problem you had?
Old   December 15, 2011, 23:22
Actually I downloaded the MSVS from MS Dream Spark so they gave me whole package which consists of Microsoft SDK V7.0A. If you want that folder I will try to send you.
I don't know exactly whether both of them(sdk and vc++) are required to compile UDF but as I have copied a file ("kernel32") from MS sdk folder to MSVS library I am guessing that both are needed.
Thanks,
Raghu
Old   December 16, 2011, 15:13
kabilan.B
very thanks for reply..
could u pls help to work udf for win 7 64bit?
pls send me needed files.
thanks
Old   December 16, 2011, 15:18
kabilan.B
hai
i have downladed as u told but in working with command prompt error shows and shows x64compiler not installed in ur system
could u pls rectify my problem?
Old   December 16, 2011, 16:37
I don't know much of this. But I will try to give you information based on the way I did it. Also, it is better if you post this separately on the discussion forum so that others can help you.
Coming to your problem, Are you talking about the command prompt opened from MSVS or opened in normal way. Can you please let me know more details what you r doing. I think you have downloaded the MSVS for 32-bit(x64). It is x86(64-bit) which you need to download.
Thanks,
Raghu
Old   December 16, 2011, 23:34
Default udf
  #11
kabilan.B
actually i m trying to load my compiled udf c file.
i m using w7 64bit...
i told already my errors could u pls solve my problem?
Thanks,
Raghu[/QUOTE]
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 15 November 4, 2019 18:05
A problem about 'printf' and 'Message' in UDF. LICH Fluent UDF and Scheme Programming 2 May 2, 2013 02:45
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 10:48
UDF compiling problem for 3D simulation Marijo FLUENT 1 March 28, 2006 03:21
