Problem in compiling UDF
Old   January 11, 2012, 03:31
Default Problem in compiling UDF
kqlee is on a distinguished road
Hi, i would like to search for help regarding to the UDF compilation.
Generally, to compile UDF, we just need to add the source file, give a library name and build it. however, when i click the 'build', the FLUENT window will pop out this sentence
"'nmake' is not recognized as an internal or external command,
operable program or batch file."
and when i load it, error occurs where it stated that the system cannot find the file specified. Is there anyone who could help me with this matter? Thanks.
kqlee is offline   Reply With Quote
Old   January 13, 2012, 06:38
mali28 is on a distinguished road
See the attached file. It has all the instructions. It works for both Fluent version 12.x/13.x
mali28 is offline   Reply With Quote
Old   January 14, 2012, 01:45
Thanks mali28,but I'm using Fluent version 6.3, so i think ur suggestion is not applicable in my condition. anyway, thanks again.
I have found a link which is useful for those who are still facing the same problem as me.
http://www.cfd-online.com/Forums/flu...ues-nmake.html
By following the instruction given, it successfully solves my problem.
Good day~
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 15 November 4, 2019 18:05
A problem about 'printf' and 'Message' in UDF. LICH Fluent UDF and Scheme Programming 2 May 2, 2013 02:45
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 10:48
UDF compiling problem for 3D simulation Marijo FLUENT 1 March 28, 2006 03:21
