fluent error
Like Tree3Likes
Old   February 7, 2012, 09:47
Default fluent error
Alessandra
alecon88 is on a distinguished road
Hi, when I tried to upload my geometry and mesh on fluent I have an error:
Building...
mesh
Error: %%create-sliding-interface: wta(sb1-id)
Error Object: ()
materials,
interface,
domains,
zones,
Error: get-thread: invalid thread id (integer) or name (symbol)
Error Object: ()
Preparing mesh for display...
Done.
Writing Settings file...
Error: inquire-adjacent-threads: wrong type argument[1] (thread)
Error Object: ()
why?
I haven't sliced edge or something else!!
JouleBrayton likes this.
alecon88 is offline   Reply With Quote
Old   February 21, 2012, 06:12
MSc
Ockert Augustyn
MSc is on a distinguished road
Have the same problem.
Can't figure it out...
What Ansys version are you using? I'm using the newest version (14). I'm starting to wonder if it is not a bug?? haha
MSc is offline   Reply With Quote
Old   February 21, 2012, 07:50
Alessandra
Me too..14 version! At the end I have "found out" removing the slice in DM!
Old   June 6, 2012, 06:05
Faby is on a distinguished road
I have the same problem!!!
what do you mean with "removing the slice in DM"?
And another question...have you two boundaries for each single interface?
Faby is offline   Reply With Quote
Old   July 23, 2012, 10:06
Ting
Chika_3045 is on a distinguished road
same problem for me, what does it mean by ''removing the slice in DM''? I need slice to generate the mesh I want.
I just update from version 13 to 14, and there weren't this error before.
Chika_3045 is offline   Reply With Quote
Old   September 5, 2012, 04:49
Thumbs up
Marin tessier
matelot is on a distinguished road
Hi !
I had the same problem...
I just reiniated the fluent "box" on the workbench
Then it worked... Don't know why so yes, maybe it's a bug !
My bad for "box" I'm french and I don't know how to say this !
matelot is offline   Reply With Quote
Old   October 30, 2012, 11:18
Default Error Messages still exists in FLUENT!
Mrt
MDinc is on a distinguished road
Hello Everyone,
I also experinced the same problem mentioned on the original post. However, I still could get rid of the error messages even though I deleted the "slice" in DM and reset/refresh the Fluent bar. What should do I then to fix these error messages? Any suggestions are greatly appreciated.
Thanks.
MDinc is offline   Reply With Quote
Old   November 1, 2012, 04:23
Default Hi members!
Võ Duy Trung
swapshot is on a distinguished road
I met a problem concern the CFD, when i create and mesh the model, it's ok. But i perform to set up it, i can't because it requires Fluent.exe, i'm using ANSYS version 14, u can help me to solve my problem, thanks all.
swapshot is offline   Reply With Quote
Old   November 2, 2012, 00:36
Dorit is on a distinguished road
Hi, I'm not sure if it helps anyone but I also had the error "inquire-adjacent-threads: wrong type argument[1] (thread)" but I managed to get rid of it, so I'm gonna post here what I did.
Firstly I'm running a simulation with rotational periodic boundary faces & a sliding mesh with periodic repeats. After setting my simulation up and having it running for N iterations I got the error when I tried to apply periodic repeats in the Graphics Periodicity panel to see the full 360 degree version of what I simulated. It turns out that this was due to the interface. After I had iterated my case I saw that Fluent created an extra entry in the Boundary Conditions panel named "periodic-xxx" which was set to translational by default (although I'd have expected rotational). This didn't let me apply the graphics periodicity.
I then ran a mesh check where everything looked as normal except that right at the end Fluent wrote "Deleting zone periodic-xxx (not referenced by mesh)". And voila, I'm now able to see 360 degree of mesh when analysing contours, stream lines etc.
Hope it helps!
Dorit is offline   Reply With Quote
Old   December 5, 2012, 15:02
Jamie Bentley
Jamie_Bentley is on a distinguished road
Same problem, it gives:
sliding_boundary_list: zone 5 type not interface
etc etc etc.
All I've tried to do is model a simple 2D channel with a porous medium in the centre. I've set the perimeter of the porous zone as an interface and the porous zone itself as an interior. I then open fluent and the above errors pop up like 10 times each while its loading. At my wits end with this thing, if anyone knows a way around setting up 3D porous problems please let me know, or email me on:
jollybadger@gmail.com
Jamie_Bentley is offline   Reply With Quote
Old   December 5, 2012, 15:03
Jamie Bentley
Sorry not 3D porous problems, 2D porous problems.
Thanks
Old   March 31, 2013, 15:08
  #12
Ravi Jogi
jogiravi is on a distinguished road
I have same problem but could not get solution.
I have meshed centrifugal pump model in hypermesh 9. then meshed file is exported to gambit for boundary condition. And then simulated in fluent. Whole simulation completes. Then I closed fluent. Then again opened fluent and read case and data file. Now fluent shows error
Error: %si-create-grid-interface: wta(int)
Error Object: (sb1-id . 6)
I can not understand where the problem is. Is it in meshing or grid interface?
Waiting for the reply
jogiravi is offline   Reply With Quote
Old   May 9, 2013, 21:19
Default Same problem
  #13
Nandish
nandish777desai is on a distinguished road
Hello
Has anyone being able to get a solution. I tried different options with my mesh in ANSYS Meshing. But no matter what conditions I use for meshing, it ends up being the "create-sliding-interface" error. I tried to open the mesh file in serial, parallel, ANSYS 13, 14 and 14.5. Same error.
nandish777desai is offline   Reply With Quote
Old   June 27, 2013, 17:37
Lightbulb
  #14
sahar
sahar_hp is on a distinguished road
Hi
I got rid of this error (get-thread: invalid thread id (integer) or name (symbol)) by this way:
if you connect the edges in meshing part with mesh connection you should delete all the contact region in the connections list and the only thing that you should have in connections list is mesh connections, hope it works for u 2.
tang400 and koustov like this.
sahar_hp is offline   Reply With Quote
Old   October 2, 2013, 20:06
Flavio G.
JouleBrayton is on a distinguished road
I am recieving exactly the same error.
Have you find a solution? I dont understand the last one explained here.
Thank you very much! I need it.
JouleBrayton is offline   Reply With Quote
Old   December 11, 2013, 20:55
Smile
  #16
tang400 is on a distinguished road
Originally Posted by sahar_hp View Post
Hi
it works. thanks a lot!
tang400 is offline   Reply With Quote
Old   December 20, 2013, 04:28
ethen
skikay is on a distinguished road
you should use hypermesh to mesh your geom,and upload to fluent,it's ok
skikay is offline   Reply With Quote
Old   September 29, 2014, 15:36
daniel
twolf59 is on a distinguished road
Hi
This worked for me in Ver.14. Thanks!
twolf59 is offline   Reply With Quote
Old   December 30, 2016, 08:58
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
Hi
I don't understand what you mean. Could you kindly explain in more detail the procedure?
Mazze[ITA] is offline   Reply With Quote
Old   April 11, 2017, 16:05
Angelina
aaangie is on a distinguished road
I have got the same problem. Ansys doesn't like slide surface. I export my geometry like .stp and create new proyect importing this .stp archive. After that fluent works without problems.
aaangie is offline   Reply With Quote
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
