8th order polynomial function(VOF smoothening) + ENO discretisation |
April 20, 2012, 02:14 |
Jacky
HI all....... I am trying to smoothen vof field in following way:
- LVIRA for finding normal to interface, - 8th order polynomial function for smoothened vof field, - ENO discretisation for convection terms I am facing follwong difficulties while implementing it in FLUENT: Q 1 - How do I get normal vector from FLUENT so that LVIRA can be implemented ? I know Fluent uses Youngs reconstruction method in which normal is -ve gradient of vof. I hv found some fluent storage variables for vof gradient viz.SV_VOF_RG So my question is can I use following for interface normal vector and thereby can I modify it by storing in it value returned by LVIRA ? C_STORAGE_R_NV(c,t, SV_VOF_RG) Q 2 - I need normal distance of interface form cell center. I found a macro in sg_vof.h viz. Get_Surface_Distance(cell_t c, Thread *t). Can somebody tell me what this macro returns ????? Q 3 -Can somebody tell me How should I implement MINMOD function of ENO discretisation scheme in FLUENT platform ? To be more precise I need to do following: du/dx = (U_{right} - U_{center})/deltaX + 0.5*dt*MINMOD(a,b) where a and b are some other complex terms.... Using which DEFINE macro or any other macro can it be done in FLUENT ???? ANY HELP WOULD BE APPRECIATED............ Regards, Bharat |
July 4, 2012, 11:51 |
cincin
hello, i am working on the same kind of problem, tracking free surface(water and air) in VOF model. and calculate the distance from the centroids of the water part to the interface. i got some suggestions of considering the interface horizontal, then using the volume fraction will essily give the answer. but it is just a rough approximation.your idea is good. have you performed it?
Second Order Discretisation with Porous Media | giogio | FLUENT | 1 | March 21, 2008 12:29 |
Higher order polynomial problem... | Markas | FLUENT | 0 | February 20, 2008 16:44 |
UDF Format 8th Order Polynomial | Jason | FLUENT | 2 | June 24, 2007 13:21 |
UDF Format 8th Order Poly Fit | Jason | FLUENT | 0 | June 8, 2007 12:36 |
Discretisation scheme in CFX-1st or 2nd order? | Pete | CFX | 10 | January 12, 2005 12:48 |
