Drag Coefficient
Old   April 23, 2012, 15:17
Default Drag Coefficient
James Hetfield is on a distinguished road
Im trying to find the drag coefficient for NACA0012
Although I have a really fine mesh, it doesnt converge and at best it gives me 50% off the experimental data
why is it like this?
James Hetfield is offline   Reply With Quote
Old   April 23, 2012, 22:58
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
You should focus on the problem of convergence beforehand. You shouldn't expect any meaningful results if the solution has not reached any type of convergence. If you give some details of how you're modelling it then maybe we can come up with reasons why it is not converging. Things like y+, turbulence models used, wall function approach, discretization scheme, etc etc. Give details if you want help!
If the solution had converged then I would have said, for Drag Coefficient
What is 50% off? Is it the drag coefficient?
Did you remember to set your reference values? You need to specify the reference density and velocity for the dragon coefficient. For force vector you also need to input the reference vector. Other coefficients use other reference values also.
LuckyTran is offline   Reply With Quote
Old   April 24, 2012, 13:01
although my mesh is fine (starts from 1e-06 normal to the airfoil surface) I dont reach convergence
what is wrong with it?
Old   April 24, 2012, 16:45
Lucky
Can you give any other details about the simulation? And wth is 1e06? How big is your airfoil? Anything? Give details!
Old   April 24, 2012, 21:21
1e0-6 is the distance of first layer from the airfoil
the chord is 1 meter
Im using C-mesh
Im trying to use SA or SST-KW for turbulence model but i cant get convergence
give me email so i cant send u "tin" file
Old   April 24, 2012, 21:53
Lucky
Im using C-mesh
1e-6 astronomical units?
Old   April 24, 2012, 21:58
1e-06 meter
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
problem with saving drag coefficient colopolo FLUENT 5 April 12, 2013 10:59
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
