SST k-w model--the parameter 'omega' does not convergence |
May 6, 2012, 00:22 |
Yangyang
Rep Power: 14 |
Hi everyone,
I use SST k-w model simulate air flow in a duct. However, the parameter 'omega' does not convergence (about 5e-2). This is happen in all my case--different mesh (good and bad) and different y+(1-20). Does anyone have any ideal to help me fix the problem? Thanks. |
May 6, 2012, 14:21 |
#2 | |
Lucky
Rep Power: 66 |
Check some actual engineering values to see your simulation is converged. Scaled residuals are a poor method for judging convergence in the first place. How many iterations have you tried? |
May 6, 2012, 16:14 |
#3 | |
Yangyang
Rep Power: 14 |
The good mesh is in smooth duct geometry with Quad map type mesh (The mesh uniform everywhere). The bad mesh is in some roughness surface duct (The skew>98). Can you tell me how can I check the actual engineering values to see the simulation is converged? I have tried 2000 iterations but the parameter 'omege' is not changed after just 25 iterations (keep at 5e-2) and other parameters are not changed after 500 iterations. Any more idea to solve this problem? Thanks. |
May 6, 2012, 16:42 |
#4 | |
Lucky
Rep Power: 66 |
Check solution values by creating point, line, or surface monitors of some relevant engineering quantities (pressure, velocity, temperature, turbulent kinetic energy, etc). |
May 6, 2012, 23:58 |
#5 | |
Yangyang
Rep Power: 14 |
Thank you for your help. |
Number of transport equations in k-w SST model | marcolovatto | Main CFD Forum | 1 | December 13, 2011 20:37 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 05:15 |
Understanding k-omega SST model source code | tmhonka | OpenFOAM Programming & Development | 1 | September 8, 2009 07:33 |
simulation results for k-w model and SST model | Li | CFX | 7 | June 29, 2007 04:19 |
