Fluent scripting question
Like Tree7Likes
  • 6 Post By LuckyTran
  • 1 Post By YorkshireTea
Old   May 7, 2012, 13:33
Default Fluent scripting question
me3840 is on a distinguished road
I'm trying to get fluent to output a projected area into the terminal window, but without user intervention. The problem is the projected area function requires you to enter in wall zones you want and hit enter when you're done defining them. Is there some command I can put in the input script that will do this? I couldn't find anything about it in the TUI manual.
me3840 is offline   Reply With Quote
Old   May 10, 2012, 11:12
olybeast is on a distinguished road
start recording journal
do all that manual stuff you just mentioned
stop recording journal
there you have a file with all the code you need in it to write your own journals
olybeast is offline   Reply With Quote
Old   May 10, 2012, 23:37
Lucky
Make a journal file. It is just a text file that lists all your TUI commands. Fluent will read the file and then enter the commands exactly as you enter them.
Old   May 11, 2012, 01:18
When I do that it fills the journal file with text commands which include GUI parameters - will that still work if you run the script on a cluster with no GUI?
Old   May 11, 2012, 01:21
Lucky
without a GUI the GUI commands will not work at all.
you need to make the same journal file using only TUI commands and that will work anywhere.
Old   May 11, 2012, 11:19
Yes..that's the problem...I don't know what the TUI command is for "enter"
Old   May 11, 2012, 13:25
Lucky
oh sorry.
If you press the enter/return key into the TUI window, a list of all available commands will be printed on the screen. You can use this to learn to navigate your way to get to the right place. Follow all the prompts and enter all the appropriate inputs.
Then write down all your inputs into a separate text file and save it as a journal .jou file. Fluent will read the file exactly as is so anything you put in the journal file will be inputted exactly into the TUI the same way. So an easy to check if your journal is setup properly.
The Fluent manual also contains a list of the TUI commands to get you started but you still need to do it a few times to get all the input strings.
Old   May 11, 2012, 13:39
Yes, I know this already. But when you choose to do something like projected areas in the TUI, it will eventually ask you for a list of wall zones to project. The only way to get it to stop asking for the list is to hit enter with nothing typed in as a zone. My question is how to "hit enter" while giving no actual name in the script. There has to be some sort of "OK" command.
Old   May 11, 2012, 13:48
Lucky
remember that it is a simple text file and will be able to interpret special characters. the enter key is simply a special character. any enters/return characters that are in the script will be interpreted (even if they are at the end of the line).
you therefore need to be careful, because if you accidentally leave a blank line, it will be interpreted as a return command, which may lead to errors afterwards such as when it is in the middle of a list of prompts.
Old   May 11, 2012, 13:50
I've tried leaving a blank line, but it doesn't do anything. I want it to be interpreted as a return command. Is there some other way to end a list of prompts?
Old   May 11, 2012, 13:57
Lucky
I think you are looking for () to signify the end of a list
Jeeloong, Sabomb, srsel6 and 3 others like this.
Old   May 15, 2012, 22:50
Yup, that's the one. Thanks.
Old   August 18, 2017, 13:36
Jeeloong is on a distinguished road
Originally Posted by luckytran View Post
i think you are looking for () to signify the end of a list
very important
Jeeloong is offline   Reply With Quote
Old   September 23, 2019, 13:49
YorkshireTea is on a distinguished road
I believe a comma , also works for 'enter'?
destroy likes this.
YorkshireTea is offline   Reply With Quote
Question about transiet simulations in Fluent Vitaly FLUENT 5 February 19, 2012 22:06
Question about modeling an elastic wall in Fluent Mosheraa FLUENT 2 June 24, 2011 18:47
Question: BC openFOAM vs. FLUENT oehmu OpenFOAM 2 December 14, 2010 16:14
a question about the liquidus temperature in fluent hunter FLUENT 0 April 13, 2009 21:55
General question regarding Fluent 6.3s mesh motion AndyRoth FLUENT 0 December 8, 2006 12:01
