May 12, 2012, 21:46 |
CL of a 2-D airfoil at AoA
Mitchell Le
I have constructed a mesh in ICEM for my NASA (SC) 0410 airfoil and have had my results converge in FLUENT to 1e-6 residuals. I am increasing the Mach number and checking the lift and drag coefficients after convergence. I am finding though that as I increase the Mach number, the coefficient of lift is also increasing. Could anyone help me out as to why the Cl is not remaining constant for the same alpha. My Mach numbers range from .6 to .8 and I am at a constant 2 degrees AoA. I am very new to FLUENT, so don't hesitate saying any answers you might think are obvious. Thanks for the help.
May 15, 2012, 04:48 |
Michal
Rep Power: 14 |
Did you make sure the reference values are suitable for each calculation?
June 8, 2012, 02:18 |
steady or transient case for airfoil simulation...
aswin vudddagiri
Rep Power: 13 |
hi..
I am doing simulation for NACA 0018 airfoil. I considered the flow as a transient and used SST turbulence model. But in many of the papers i have found using steady flow. But how can flow over an airfoil will be steady?? can anyone help me of when to use steady/transient for simulation of airfoil and the flow physics for simulating the airfoil.. Thank you. |
June 8, 2012, 16:36 |
Mitchell Le
The flow will be steady with time. Meaning the model will converge on one solution. Flow over an airfoil can be unsteady, but if you are doing an airfoil at typical flight conditions, Ive found the flow to always be steady. I havent done an abundance of models, but that is my two cents.
June 9, 2012, 03:24 |
aswin vudddagiri
Rep Power: 13 |
thank you mitchell....
June 9, 2012, 03:53 |
Rep Power: 20 |
Flow over the aerofoil becomes unsteady due to large turbulence and flow separation. Flow separation and turbulence is dominant at higher angles of attack especially near stall. So you can run steady simulation at smaller angle of attacks but u can't run unsteady simulation at higher angle of attacks
June 9, 2012, 05:38 |
aswin vudddagiri
Rep Power: 13 |
so can i run steady simulation until the stall occurs??
January 15, 2013, 09:17 |
Wheeler
Rep Power: 13 |
Increasing the MACH means increasing the RE.It's obvious that the Cl would increase.
2-d, airfoil, lift coefficient, supercritical |
Simulating flow past airfoil with different AOA | ramin | FLUENT | 4 | April 22, 2015 13:09 |
ERROR: End AOA in airfoil table too small k 1 i 1 in Fluent 6.3 | Asela | FLUENT | 0 | September 8, 2010 06:53 |
simulation of airfoil at high AOA | hsnu84053 | FLUENT | 0 | January 26, 2007 21:34 |
Simpliest way to run airfoil simulation diff AOA | Ben | FLUENT | 0 | November 19, 2006 02:11 |
Simulating flow past airfoil with different AOA | Quarkz | Main CFD Forum | 2 | January 6, 2006 10:56 |
