hi
Old   May 15, 2012, 07:57
Default hi
nabizadeh
eb.nabizadeh is on a distinguished road
i want to simulation one house with ansys fluent 13,but i have some problem with viscosity model who can help me?the model is 3D and the wind velocity is 3m/s.plz give me the detailed i need for this model
eb.nabizadeh is offline   Reply With Quote
Old   May 15, 2012, 08:00
nabizadeh
plz help me quick thanks
Old   May 15, 2012, 08:05
Zigainer is on a distinguished road
Could you just write some more details? What are you interested about? Where exactly is your problem?
Maybe a sketch would help to understand your problem.
Zigainer is offline   Reply With Quote
Old   May 15, 2012, 08:35
nabizadeh
ok,my model is a 3D house that has wind catcher,the boundary condition is:
inlet:velocity inlet and the amount of it's is 3m/s
outletressure outlet and the amount of it's is atmospheric pressure.
rest of house wall boundary condition is wall
when i run the fluent i see some sentences like reverse flow or limited viscosity ... or limited temperature ...
what i must do to correct it?
Old   May 15, 2012, 08:55
nabizadeh
thaaaaaaaaaaaaaaaaaanks
Old   May 15, 2012, 09:34
nabizadeh
one person give my answer
Old   May 15, 2012, 09:55
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi
first of all I think that there isn't any thermal boundary condition so you should disable the Energy equation (so that the temperature will not be calculated)
The message "reverse flow..." means that the flow direction is opposite to the output: this isn't a problem if the number of the cells with this flow decreases during the iterations (try waiting after hundreds of iterations what happens)
Best regards
Bionico is offline   Reply With Quote
Old   May 15, 2012, 10:08
nabizadeh
thanks dear.and do u think whats the best viscose model and if i want to use radiation what is the best model for this simulation?
Old   May 15, 2012, 10:39
Bionico's Avatar
Flavio
ok, I was wrong: if you have to use a radiation model the energy equation must be selected
- Viscous: I think that a simple standard k-epsilon model can be suitable in your case
- I'm sorry but with radiation fenomena I haven't much experience: I only know that the most complex model is DO, but I think that in your case you can select a simpler one
Old   May 20, 2012, 07:55
Smile
nabizadeh
i have one question,my model is transient and i want to see the answer in different time what i must do?
Old   May 20, 2012, 07:56
nabizadeh
thankssssssssss
