Convergance problem
Old   May 23, 2012, 20:15
Default Convergance problem
Osama
osamaghani is on a distinguished road
Hi.
I have been running some simulations simple geometry. A rectangular 2D geometry with fillets and chamfers on front.
domain is approx 9500mm(length) x 5000mm(height). the rectangle is 400mm(height) x 1000 mm(length).
continuity residual does not converge(drop below 10e-6) even after 20,000 iterations. it varies in the range of 10e-6 and fluent does not say solution has converged ..other residuals drop to 10-8. and the Cd value does not change for more than 100 iterations..
the mesh quality is also good;
cell squish varies between 0.2 to 0.55..
for example, for one case.its;
Mesh Quality:
Applying quality criteria for quadrilateral cells.
Maximum cell squish = 3.92392e-001
Maximum aspect ratio = 2.68100e+001
I have also checked the values of wall Y+ on the rectangle and they are also approximately in the range of 30-300 as I have used standard wall function..
regards,
Osama
osamaghani is offline   Reply With Quote
Old   May 23, 2012, 22:58
Far
Sijal
Your solution is converged
convergance
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Free Surface Problem - Convergance Toby FLUENT 0 July 2, 2008 23:16
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
