Rep Power: 14 ![]() |
Hi all,
I am having trouble initializing my multi-fluid vof model in Fluent. I am trying to simulate a simple open channel flow over a bump for a uni assignment. My primary phase is air, and secondary phase in water. I am attempting to patch within fluent by adapt>region>mark, I then patch that region in initialization but when I view the volume fraction plot it is all the primary phase (air). Is there something im missing? Thanks |
Rick
Rep Power: 26 ![]() |
Hi, make sure to:
- Adapt->Region.... Choose either Quad or Circle for 2D. Enter the Input Coordinates, and press Mark. - In the Patch window, a new item just appeared, something like hexaedron. select this, write inputs and patch. Daniele |
Vaze
Rep Power: 17 ![]() |
Hi svanmunster
Also make sure following - If you mark the cells from secondary fluid side then define volume fraction 1 for secondary phase in that marked domain. otherwise reverse the situation. Regards mvee |
#4 | |
Another quick question if you dont mind. When viewing the volume fraction contour plot of the flow, there are values that are not equal to 1 or 0 but rather intermediate values. Does this mean that the water is mixing with the air??? That shouldnt be happening? |
#5 | |
Rick
A quick search on forum returns an old reply of amir: Question: When I patch a small volume I get an avaraged value of the specified parameter at the marginal grid of the volume. How can I avoid it? answer: it doesn't occur if you display cell values not node values. (you can set that in display->contour) Daniele |
Can't seem to find that option. Nevermind I can live with it (as long as fluent doesnt think it is mixing). If you dont mind danielle I have a further question in regards to viewing the velocity vectors/contours. With the multi-phase fluid I only have the option to view the velocity of the 'mixture' whereas I am only interested in the velocity of the water. Is there a way around this?
Thanks again! |
Rick
In the display->contour (the window where you choose "contours of.." and you click "display" to see contour) deselect "node values" and you will see only 0 / 1 vapor fraction.
Either in the display->contour you shoud see the option to change from mixture to phase-1 or phase-2 (choose velocity, then change from mixture to phase-1, assuming phase-1 is water). Daniele |
http://img856.imageshack.us/img856/3302/cfdforum.jpg
I have uploaded a photo which shows my issues. As you can see there is no option to select anything other than 'mixture' in the drop down box. I have also unchecked node values in display but as you can see the volume fraction contour plot is still taking intermediate values. Also, I am trying to simulate a hydraulic jump do you have any idea why the flow beyond the bump is not jumping? Thanks again. |
#9 |
Rep Power: 12 ![]() |
Hello dear friends,
I try to simulate melting process using VOF model. Pcm is solid phase initialy. Upper part of the solid there is air. They do not mix eachother. he rectangular box is %85 full with solid pcm, %15 air. Natural convection is active. My primary phase air, secondary phase is pcm (phase change material). I have some questions to be sure about my model. First, I do not define interface between air and pcm. Mean, There are 3 cell zone: air, fin ,pcm but I do not create name selection for this interface in meshing. Is it ok? Initial condition of Wholesystem temperature is 293K, but air temp is 300K. how to set air temp ? For cell zone condition, all cell zone (air, pcm, fin ) show mixture. Also for example, if I change pcm to phase2, all of cell zone change to phase 2 Only for secondary phase (pcm), I patch within fluent by adapt-region-mark then patch. Ok? Value of volume fraction should be 1 or 0 while patching?? I am confused. Initialy pcm is solid. For initial values phase-2 volume fraction is 0. Ok? I did some iteration for a short time to check model. For results, in graphics-countors I can not see total temperature for phase 1 and 2 only entalphy values I see for phase1 and 2. Also countors of solidification/melting it shows only mixture. Mixture show what? Any interaction should I use like surface tension etc. Thanks for your help. ı am really in stuck. good work friends. Last edited by thermal energy; March 15, 2014 at 07:05. |
#10 |
can any one tell me how to plot velocity vector in multiphase??
when i m plotting it velocity of phase 1 it is not showing any thing in display but it is working with phase 2... |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 01:22 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Multifluid flow | Rajendrakumar | Siemens | 1 | April 13, 2007 04:25 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
