Periodic boundary conditions for 2D pipe (water flow). |
#1 | |
Krzysztof
Rep Power: 14 ![]() |
I'm an MSc student looking for an advice about periodic boundary conditions. I've modelled 1 metre long pipe, 40mm diameter (see attached). Boundary conditions defined in ICEMcfd were: inlet - velocity inlet, topwall - wall, bottomwall - wall, outlet - pressure outlet. After loading model into fluent I've applied all necessary parameters like materials, BC's, methods and solver. Then I've performed test calculation to see if solution is converging - well it converged (after ~2000 iterations). Next step is to change bc's into periodic. The goal is to get fully developed flow. I've followed the instructions from fluent manual: Quote:
Well after 30000 iterations i still have no solution, and it does not seem to converge. I've tried different mesh densities but the problem still exist. I'm not sure about my periodic boundaries implementation? Can anyone suggest me where the mistake is? I'd appreciate anyhelp. Regards. |
AHMAD
Rep Power: 0 ![]() |
Have you tried to increase the number of subiterations that been done on the pressure correction. |
Krzysztof
Thanks for the reply. I changed it, simulation is running. But so far I haven't noticed any difference. Well, I'll give it some time. But I'm afraid it wont solve my problem ![]() |
AHMAD
If it doesnt work, try to make your mesh using ANSYS standard mesher.
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
Pipe Flow Boundary conditions | Kunal Jain | Main CFD Forum | 0 | September 4, 2001 20:52 |
