June 2, 2012, 17:29 |
Dynamometer, 2D Axisymmetric!
Khayyamian
Rep Power: 15 |
Hi All;
I am working on a dynamometer (you dont need to know what it is!!!), and for simplicity I changed its geometry as in Fig.1, as you can see water is inside a cylinder which contains a rotor spinnnig with angullar velocity of 5500 rpm. I set my Computational Domain like in Fig. 2. Note that there is no any inlet and outlet in this analysis to decrease computational difficulty. Through my case setup in Fluent I did following: 1- Pressure Based- 2d Axisymmetric swirl (I dont know why I cant use just 2D Axisymmetric ??)- Absolute Velocity Formulation 3-Viscouse: I used Laminar, k-e and spalart-... 2- Material water; I assumed constant density 3- BC: Fluid zone as single rotating frame (its rotation axis is x-axis as stated in Fluent Docs) , angular velocity of 5500 rpm4- First Order Discritization Scheme for starting iteration and then shift 2 2nd order. For pressure I selected PRETSO! though. 5- operating pressure: about 3 bars, since I know from experiment its pressure is in that range. 6- initialization: just changed pressure from zero to 2 bar. My results: Although solution converges, result is crazy. for example the inside pressure varies for -3 bar to 100 bar! I also checked my Y+ value. it was alright. I would appreciate if you reply anything you may think useful regarding my problem! Regards. |
June 3, 2012, 04:45 |
xrs333
Rep Power: 16 |
Nihao, Khayyamian,
I think i can explain your puzzle. Your model has no flow inlet and outlet, and the flow is imcompressible, so the pressure in the model is floating. To overcome this, define the operating pressure at a position in the domain. |
June 7, 2012, 13:10 |
Khayyamian
Rep Power: 15 |
Thanks xrs333 for your fast reply!
I will check out what you mentioned, it takes some days though. I will notify then. But I asked another question, what if used 2D Axisymmetric without Swirl but wall still moving? |
June 8, 2012, 06:41 |
Rep Power: 17 |
2D axisymmetric without swirl with not capture the effect of the rotating wall on the fluid and hence your results will look the same as when your wall does not rotate.
Regards Luke |
July 27, 2012, 03:06 |
please help me in 2D axisymetric?
vahid
Rep Power: 13 |
Im produse 2Daxisymetric.
but after run , my results is not one with 3D???and incorrect!!!! Have i correct boundary type? axis:empty (empty or symmetryPlane is correct?????? ) wall:wall inlet: patch outlet: patch frontAndBackPlanes:empty frontAndBackPlanes_pos:wedge frontAndBackPlanes_neg:wedge please tell me my mistake! |
July 27, 2012, 04:05 |
Alex
Rep Power: 47 |
The case you have is not axisymmetric. The main velocity component is the tangential component, which is not even computed in an axisymmetric case.
The right way to model your case is with a periodic boundary condition and a 3D geometry or as axisymmetric swirl. |
July 27, 2012, 07:36 |
an other question
vahid
Rep Power: 13 |
Hi dear Alex S.
Thanks for your answer.axisymmetric swirl??? please learn me more for this idea!!! |
July 27, 2012, 08:26 |
Alex
Rep Power: 47 |
You will learn much more about it by reading the section "axisymmetric swirl" in the Fluent manual.
July 27, 2012, 09:29 |
an other question
#9 |
vahid
Rep Power: 13 |
I worked with openFoam!!!why you tell me fluent???please tell me Details about it.
July 27, 2012, 10:24 |
#10 |
Alex
Rep Power: 47 |
Because this is the FLUENT subsection of the forum.
I know nothing about open foam. |
July 27, 2012, 10:29 |
ohhhh
#11 |
vahid
Rep Power: 13 |
ohhhhh!!!!!Im very sorryyyyyy!!!!
thanks. |
2d axisymmetric swirl, dynamometer, single rotating frame, wrong pressure |
[Commercial meshers] 2D axisymmetric simulation starting with a 2D fluent msh file.... How ? | vishalsacharya | OpenFOAM Meshing & Mesh Conversion | 0 | November 17, 2011 00:29 |
Convertation axisymmetric cases from Fluent to OpenFOAM | Svensson | OpenFOAM | 0 | April 19, 2011 06:08 |
Axisymmetric Swirl | Arpit Tiwari | Main CFD Forum | 1 | September 15, 2010 05:45 |
Level set equation in axisymmetric 2-D flow | jinwon park | Main CFD Forum | 0 | February 26, 2008 16:26 |
URGENT ! Need help on Axisymmetric Flow ! | Suman Kumar | Main CFD Forum | 1 | November 20, 2001 14:51 |
