June 30, 2012, 20:25 |
Turbine simulation
Sarah4
I saw some of the posts sharing experences doing the Phase vi turbine simulation.Some people are very successful on this. Currently i am doing the same thing to learn cfd. It is greatful if you could give me some suggestions: 1. What is the first height of your mesh to get an relatively accurate result? Say height of 0.01mm, this kind of mesh always resulted in bad cells. Can we change the sharp trailing edge to blunt trailing edge as the real blade? 2. When using two domains (one is rotational and the other one is stational) to simulate the flow around a turbine, should we define the flow rotational direction the same as the blade rotating direction (say "+Y")(turbine drive flow), or we define "-Y" for the flow? I got two different results but both positive torque. ... Thanks in advance for your reply. |
Simulation of Wind Turbine with OpenFoam | be_inspired | OpenFOAM | 52 | September 6, 2018 10:33 |
Verifying results for a wind turbine blade simulation in ANSYS CFX | Joystix | CFX | 3 | April 27, 2012 17:52 |
radial turbine blade simulation with dynamic mesh 6dof(fluent) | mamyjooooon | FLUENT | 0 | April 7, 2011 14:28 |
wind turbine simulation | moca | CFX | 1 | July 25, 2009 06:48 |
cfx turbine simulation | mehrdadeng | CFX | 0 | March 31, 2009 05:08 |
