Export/Import data contour plots with Matlab
Like Tree3Likes
  • 3 Post By Bodo1993
Old   July 5, 2012, 15:59
Default Export/Import data contour plots with Matlab
Casey
meangreen is on a distinguished road
Hi Everyone,
I would like to make contour plots using matlab from my Fluent data, but I can't figure out how to sort the data so that matlab can plot it. (I am working in 2D and axisymmetric)
Fluent provides one long list of x coordinates, one long list of y coordinates and on long list of variables. But this isn't how matlab wants to plot things.
Has anyone written a function in matlab to rearrange the fluent output so they can plot the contour plots in matlab?
My mesh uses adaption, which makes things complicated.
Casey
meangreen is offline   Reply With Quote
Old   August 16, 2012, 19:15
Negin Nazarian
nenazarian is on a distinguished road
Hi
I have the same problem as yours. Do you remember how you solved this?
any help is appreciated.
Cheers
Negin
nenazarian is offline   Reply With Quote
Old   August 20, 2012, 08:51
Casey
Still haven't been able to solve it. Let me know if you make any progress. I have been using paraview, but it doesn't provide the same amount of control as I would like.
Old   August 21, 2012, 01:28
blackmask will become famous soon enough
You could use interp/interp2/interp3 functions provided by MATLAB to interpolate your result to structured grids. TECPLOT is a better choice than MATLAB for data visualization.
blackmask is offline   Reply With Quote
Old   July 27, 2017, 06:56
ehsan
e_cfd is on a distinguished road
you can export any contours from FLUENT to MATLAB following these steps:
1- Export what you want from File\export\solution data. (file type : ASCII and delimiter should be space).
2- use uiopen ('file address',1) in MATLAB.
3- delete characters in the first line of opened script.
4- save it on the previous file (just Ctrl+s)
5- c=dlmread('file address')
Done !
c usually is a N*4 matrix, (node number, x-coor, y-coor, contour parameter)
Regards
Ehsan
e_cfd is offline   Reply With Quote
Old   September 6, 2017, 07:46
Bauta Steen
bsteen is on a distinguished road
If you have exported your Fluent grid and data in Ascii format you can use the FEATool Matlab FEM Toolbox functions to plot contours on general unstructured grids (as well as perform further postprocessing). A few examples of possible plots and explanation of the syntax is given in this postprocessing tutorial.
bsteen is offline   Reply With Quote
Old   June 23, 2020, 11:44
Default could you send me the code for me to understand it,I have uploaded the data, please h
hitzhwan is on a distinguished road
could you send me the code for me to understand it,I have uploaded the data,I want to put all the data in one data.xlsx, please help me do it. Thank you.
hitzhwan is offline   Reply With Quote
Old   October 26, 2020, 13:48
Bodo1993 is on a distinguished road
Hi, I am wondering if you got any clue on how to do the surface plot in MATLAB accurately. Thanks.
Bodo1993 is offline   Reply With Quote
Old   October 27, 2020, 10:54
Default Do you have other methods except for the matab,I have not used the surface plot befor
Do you have other methods except for the matab,I have not used the surface plot before?
Old   October 27, 2020, 10:57
Hi, I actually do the postprocessing with MATLAB. An alternative would be python, but I do not use it.
Old   October 28, 2020, 09:27
Default Could you send me one code example for me ,thank you.
  #11
Old   October 28, 2020, 10:06
Hi, I use the few lines of code below.
    del_x = ... %element size in the x direction
    del_y = ... %element size in the y direction
    m=dlmread('filename.txt'); %reading the data from text file
    x = m(:, 1);       %x-coordinates
    y = m(:, 2);       %y-coordinates
    z = m(:, 3);       %variable
    [X,Y]=meshgrid(min(x):del_x:max(x),min(y):del_y:max(y)); %matlab mesh
    Z=griddata(x,y,z,X,Y); %interpolation
    contourf(X, Y, Z); %contour plot
Hope it helps.
Matlab contour plots Chris CFX 17 October 29, 2020 04:32
Any way to extract data from contour plots using paraView? Angela Wang OpenFOAM 10 December 3, 2017 20:37
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
