nauman hashmi
Rep Power: 13 ![]() |
Hi every one, i am facing a problem. i want to calculate lift of a body placed in far field. i m using SA model and 0.7 mach as boundary condition. what values should i feed in area, and length while i am computing results from far field.guidance in this regards is required.
thanx in anticipation |
Elias Paez
Rep Power: 14 ![]() |
The lift that fluent calculates, is just a coefficient between the lift force (lets say in newton) and the 0.5*rho*A*v^2 wich are the reference values that you put in Fluent. Usually the area "A " is the proyection area of the body in the plane perpendicular to the far flow. In this case, i think that you dont need the reference lenght.
On the other hand, if you just want to know the lift force in newton, i recomend you to calculate in report> forces. |
Lift and drag calculation | Franny | CFX | 16 | November 27, 2019 13:47 |
What is the Basic Calculation of Lift Coef In Modelling 2D?? | teguhtf | FLUENT | 0 | October 14, 2009 04:52 |
Lift calculation | icem-noob | CFX | 1 | June 23, 2008 06:37 |
Calculation of lift and drag coefficients | Prachi | CFX | 3 | August 14, 2007 14:05 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
