July 10, 2012, 17:31 |
Double Precision Solver
Anj
Its a convective heat transfer problem. I have water flowing through a channel of dimensions 0.2x0.1x12.5mm, with constant heat flux applied on the walls of channel. The inlet and outlet faces are 0.2x0.1mm. Should i use double precision solver ?
July 11, 2012, 00:59 |
Alex
Rep Power: 47 |
It depends on other details of the setup than you gave.
Is there a large difference between the extent of the smallest and the biggest cell in your grid, for example because you are resolving the boundary layer with Y+ < 1? Or is there any need to account for very small values of a variable? If in doubt, go for double precision. It is just the amount of memory usage that will be doubled, the computational time will increase only slightly. |
July 11, 2012, 11:22 |
Anj
thanks flotus1
The cells are of uniform size. I was worried because channel walls are of silicon with thermal conductivity of 148W/m.K, while that of water thermal conductivity is 0.6W/m.K (ratio of thermal conductivities is high). Also, the cross section of channel is much smaller compared to its length. |
double precision solver |
Steady state chemistry | linnemann | OpenFOAM Running, Solving & CFD | 14 | April 7, 2015 13:10 |
return a normal number to solver in double precision mode in udfs | payam_IUST | FLUENT | 1 | February 13, 2012 07:06 |
Double precision & User Fortran | Martijn | CFX | 3 | April 4, 2009 05:43 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Double precision CFX | Vanessa | CFX | 8 | August 13, 2006 04:34 |
