Inlet Boundary Conditions to model Slug flow in pipes
Old   July 12, 2012, 09:55
Default Inlet Boundary Conditions to model Slug flow in pipes
Abdullah Salih
A.Salih is on a distinguished road
I am currently working on modelling slug flow in pipe with 90 deg. bend, simulating the two-phase flow of air & silicon-oil.
At the moment I am facing a problem in determining the inlet boundary conditions using FLUENT.
Basically, according to some peoples' work they set the inlet BC as Velocity-inlet and specified the superficial velocities and the volume fraction of liquid. ( of course the multiphase model is VOF).
But, when I try to set the velocity of phase1 (silicon-oil) and phase2 (air) I find that under the tap in which I should enter the values, a message appears saying that: " This page is not applicable under current settings".
Do you have any idea about what this might be from? and what should I do?
A.Salih is offline   Reply With Quote
Old   July 13, 2012, 16:18
Jabba is on a distinguished road
Are you working with only one inlet for both fluids?
When using VOF, it is recommended to set an inlet for each fluid separately.
I have tried to set up only one inlet using mass flow boundary condition, setting different mass flows for each fluid. At the entrance region, I cannot get a defined interface, something like a homogenous flow. At some place, it develops an interface and the slugs are formed.
I suggest that, if you try this method, extend your entrance region so the flow may develop and the slugs appear at some place before the bend.
I am not sure if it would get reliable results due to the homogenous characteristics of the flow near the mass flow boundary.
I believe that modeling two inlet for each fluid will be better. However, also you will have to model a development length just before the bend.
Jabba is offline   Reply With Quote
Old   July 16, 2012, 10:33
Abdullah Salih
Hello Jabba,
Basically the experimental work which I am trying to simulate has one inlet for the both phases.
I have tried what you've suggested, to use Mass-flow BC, but the following message appeared: Global courant number is greater than 250.00 The
velocity field is probably diverging. Please check the solution
and reduce the time-step if necessary.
Can you please show me how to make an inlet for each phase so that I can give it a try?
and by the way, the distance from the inlet to the bend is about 5 m , so I guess it should be fine to achieve development.
Old   July 16, 2012, 11:00
Hello Jabba,
You may create a 3D model of a T or Y-shaped device and use the two inlets separetely.
It seems that your problem is related to the time-step size used. What is this value and also the size of your cell and fluid velocity?
Old   August 2, 2012, 14:44
zainab
zainab is on a distinguished road
Hello Jabba
I working on slug flow in horizontal pipe but the shape of slug not appears, I use one velocity inlet for the pipe, how can I setting separate inlets.
thanks.
zainab is offline   Reply With Quote
Old   August 2, 2012, 18:50
Originally Posted by zainab View Post
Hello Jabba
thanks.
you have to generate a 3D CAD model with two separate inlets merging in a single development tube
Old   August 3, 2012, 16:31
zainab
Hi every one
I am realy need to help, i working on modelling slug flow in horizontal pipe with FLUENT, but i never get the true phase distribution, what can i do? the time is v ery important for me, how can i modelling initially the stratified shape as in the figure below.
thanks.
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 07:26
Open Channel Flow Boundary Conditions TWaung STAR-CCM+ 2 October 7, 2011 00:37
Inlet boundary conditions Mattia CFX 0 February 9, 2009 13:25
