Different solutions for Rotating Reference Frame
Old   July 18, 2012, 13:12
Angry Different solutions for Rotating Reference Frame
fafou09 is on a distinguished road
I am sort of a beginner in Fluent and ICEM, but I am using those software to model flows in a reactor.
The main model is a 3D one, but due to strange results I am now using only a 2D model to understand where the problems are coming from (basically a cylinder with a shaft).
The problem I have comes from the velocity observed near the outer wall of the cylinder.
I observe 2 cases:
1) rotating reference frame with velocity of 100 rpm, rotating shaft with 0 relative velocity and rotating walls with 0 absolute velocity
2) stationary frame and walls with rotating shaft at 100 rpm.
In the case 2, I have a good behaviour: the velocity decreases until 0 at the wall. However, in the case 1, it decreases then increases near the walls and is 0 at the wall.
But this increase does not make sense and the results should be the same in both case.
Am I missing something with the rotating reference frame, because in this case it is ok to use a stationary frame but for the 3D model with impeller, I will very likely need to use the rotating one.
I attach the velocities in both cases so that you may understand better my problem.
Thank you for your help.
fafou09 is offline   Reply With Quote
Old   July 24, 2012, 10:06
Does anyone have already seen the same problem?
It does not make sense to me, but I really do not understand why I have this difference in the solution.
Thank you very much!
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
