help - Running Converging Diverging Nozzle with a shock wave
Prev Previous Post   Next Post Next
Old   September 3, 2012, 08:23
Red face help - Running Converging Diverging Nozzle with a shock wave
Daco is on a distinguished road
Hi!
I have recently started to work with fluent using the tutorial in the link:
https://confluence.cornell.edu/displ...ow+in+a+Nozzle
They solved the nozzle problem for the case the flow is supersonic in all the nozzle with no shocks. I have succeeded to recapture their results.
Next I tried (independently) to solve the same geometry with a higher outlet static pressure to get (theoretically) a shock wave in the diverging section of the nozzle.
The total pressure at the inlet is atmospheric (101325 Pascal).
I tried to input several outlet pressure: 20,000 Pa, 30,000 Pa and such
and after running the program the solution didn't converge and I didn't get any good results (the residuals went up instead of down)
My question is, What could be the cause for this divergence?
As I said, theoretically, A shock wave should occur.
Does it require any special attention? setup settings or meshing.. etc.
Could it be that the divergence occurs due to a too coarse mesh?
(I was told that the mesh in the tutorial is quite coarse)
Thanks ahead ,
Daniel
Daco is offline   Reply With Quote
about local bump shock wave drag reduction fxzf Main CFD Forum 5 February 26, 2010 12:04
Shock Wave usker STAR-CD 8 July 8, 2009 13:22
Shock in nozzle - dangerous? Christian Main CFD Forum 1 May 8, 2006 12:48
Shock Capturing in a Con-Di Nozzle. Meriem Allouache Main CFD Forum 3 December 27, 2004 05:49
Shock wave in Nozzle Mohammad Main CFD Forum 0 May 16, 2002 11:33
