problem with mass inlet
Old   October 13, 2012, 13:15
Default problem with mass inlet
Milan
Falcon is on a distinguished road
hi colleagues.
I need some help with mass inlet, because I have a problem about input flow. My flow is 0.005 and consistently throws me an error.
Is it possible to work with such low flow rates, because when you put the alarm again one mistake. How to define?
Falcon is offline   Reply With Quote
Old   October 13, 2012, 13:26
Syavash Asgari
syavash is on a distinguished road
Originally Posted by Falcon View Post
hi colleagues.
What is your problem exactly?!
syavash is offline   Reply With Quote
Old   October 13, 2012, 14:38
Milan
I have a small amount of water vapor that evaporates into a large amount of air. How to simulate. whether to put the vapor mass-flow inlet and if so how to define it.
Flow is known to me from measurement and is 0.005
Old   October 13, 2012, 14:45
Syavash Asgari
please explain your geometry, boundary conditions, aim of simulation etc so that we can help. What is 0.005? is it mass flow rate? mass fraction of water vapor? or...?
Old   October 13, 2012, 15:18
Milan
I have a vaporizer for milk rectangular profile, one inside the other. At the entrance are the following: Preasure inlet, temperature 30C, speed 0.7 m / s 70% humidity. Other walls are at 85C.
The upper edge of the inner profile of the milk temperature 100C. Simulates the process of cooling of milk, which brings the temp 100C in an air channel. to determine how much moisture flux and indulging in the airflow.
I am the first to put my surface edges with milk inlet preasure but I think it is better to work with mass-flow inlet.
Old   October 13, 2012, 16:24
Syavash Asgari
Oh! That is not quite simple for me to understand. Any way, now what part is difficult to handle?
p.s.: Is it possible to upload an image of geometry plus B.C.?
Old   June 3, 2013, 12:46
Milan
It does not matter, I finished
sorry I'm late with the answer
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
mass imbalance in wind tunnel problem Robert2011 FLUENT 0 January 25, 2011 06:46
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 16:01
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
