mesh check failed
Old   October 28, 2012, 11:15
Default mesh check failed
yss
flabbergasted is on a distinguished road
Hi, I'm using harpoon to mesh a model of an airbus A320 and fluent to then analyse flow to study wake formation but when I read the mesh in fluent and check the mesh the following error is reported- 1 degenerated contact points identified. WARNING: Mesh check failed.
What should I do?
flabbergasted is offline   Reply With Quote
Old   October 29, 2012, 03:08
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
Maybe your mesh's skewness is too high and you have some cells with negative volumes. That is what I realize of "contact points identified". Try to locate the bad cells in your computational domain and remove them.
Hope it's helpful,
Best.
vicarious is offline   Reply With Quote
Old   October 29, 2012, 08:50
Nickul's Avatar
Nick
Nickul is on a distinguished road
Long way to do it; chop your mesh in half , try reading that in, if it works then the problem is in the other half, or vice versa. Keep chopping it up until you find your problem.
A simple aero calculator
www.caided.co.uk
Nickul is offline   Reply With Quote
Old   January 24, 2013, 01:22
Talking
davia
Striving is on a distinguished road
What should I do?
i have the same problem,are you solve it?
Striving is offline   Reply With Quote
fluent, harpoon, mesh
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
mesh check failed / degenerated contact points shohin FLUENT 16 April 11, 2014 22:32
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[ICEM] Understanding check mesh output kotimari ANSYS Meshing & Geometry 0 July 15, 2012 08:33
