November 10, 2012, 13:36 |
reference value
Amir
hi all . I, m the new user of the fluent. i want to ask about the reference value. when the program use its parameter ? please specially explain about "area" , "length" , "depth" and density . thanks in advance.
November 13, 2012, 10:33 |
Do you have access to the fluent user guide? In fluent, go to the top right to "help" and search "reference values". It should bring you to section 36.10 about reference values. Basically fluent uses the reference values to calculate any "normalized" values. Such values would include reynold's number, pressure/force/moment coefficients, specific heat ratio, kinematic viscosity, etc... More specifically, for example, if you wanted drag coefficient, fluent would use the values you input for density, area, and velocity in the drag coeff. formula. The reason I point you to the user guide is because it specifically goes through each type of reference value and which normalized quantities come from each reference value. Hope this helps!! |
November 15, 2012, 06:34 |
Amir
thanks a lot . it really help.
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
