November 17, 2012, 02:41 |
Question about Fluent MHD module
Naveen
Hello Fluent users,
I am a beginner in Fluent. I want to learn the MHD module of Fluent. I am using Ansys 14.0. First to familiarize with the work flow process, I went through lot of tutorials. Then, I simulated the simple Plane Poiseuille flow building the case from scratch. At the end of the simulation, as expected I could see fully developed parabolic velocity profile at the exit, which matches with the analytical solution. After this, I wanted to simulate the Hartmann flow (MHD analog of plane Poiseuille flow). I enabled the MHD model and chose Hartmann number to be 20 (B_y= 7.64 Gauss, Please look at the attached doc Hartmann flow). After finishing the simulation, I plotted the velocity profile at the exit and could see the flattening of the velocity profile (please look at attached doc Hartmann flow2), which indicates that Lorenz force is included in the momentum equation. BUT, I saw something weird in residuals. I am pasting the few lines of the residuals iter continuity x-velocity y-velocity uds-0 time/iter 67 2.0441e-03 2.5810e-04 1.7439e-06 0.0000e+00 0:02:18 433 68 1.9700e-03 2.5377e-04 1.6280e-06 0.0000e+00 0:01:50 432 69 1.9788e-03 2.4879e-04 1.5121e-06 0.0000e+00 0:02:54 431 70 1.8832e-03 2.4463e-04 1.3903e-06 0.0000e+00 0:02:19 430 71 1.8296e-03 2.4055e-04 1.2924e-06 0.0000e+00 0:01:51 429 72 1.8519e-03 2.3598e-04 1.1889e-06 0.0000e+00 0:02:54 428 73 1.7622e-03 2.3213e-04 1.1002e-06 0.0000e+00 0:02:19 427 74 1.6380e-03 2.2828e-04 1.0365e-06 0.0000e+00 0:01:51 426 75 1.5052e-03 2.2433e-04 9.8247e-07 0.0000e+00 0:01:29 425 76 1.4334e-03 2.2096e-04 9.0770e-07 0.0000e+00 0:02:35 424 77 1.3249e-03 2.1788e-04 8.6937e-07 0.0000e+00 0:02:04 423 What is this uds-0? is it related to the Poisson equation for electric potential? Why is this always zero? is this normal? I appreciate your help. Thank you |
November 17, 2012, 15:14 |
Naveen
No one is familiar with MHD module here??
October 17, 2013, 19:57 |
mahyar
October 20, 2013, 00:21 |
Yanlong Li
If your simulation is 3D, there should be three uds (uds-0,uds-1,uds-2 stand for B_x,B_y,B_z), which are three equations.
The rediduals is weird, check your setting. |
January 21, 2015, 04:37 |
The operation sequence is very important
Rep Power: 11 |
According to my experience, we should first do the regular initialization and then do the MHD initialization at the MHD panel. When we do the initialization at the MHD panel, it is also important to first click the button "initialize MHD" under "solution control" label and then click the button "Apply External Field" under the "External Field B0" label. The sequence is very important.
May 30, 2016, 09:15 |
fati
Rep Power: 9 |
hi every body
in my simulation, I should calculated the electric field intensity and so computing aggregation rate with writing udf ,in population balance model, becouse the electric field causes agregation. can I compute the electric field intensity with mhd model? and in writing udf,I do not need to calculate the field through the writing udf? thanks |
MHD in Fluent | lg88 | FLUENT | 5 | October 18, 2018 13:29 |
mhd in fluent | ambrish4u | FLUENT | 1 | November 1, 2012 13:53 |
B vector in mhd module. | adamo | Fluent UDF and Scheme Programming | 7 | May 22, 2012 06:26 |
Mass Transfer and Fluent (scrubber question) | chickens | FLUENT | 0 | November 4, 2011 21:47 |
General question regarding Fluent 6.3s mesh motion | AndyRoth | FLUENT | 0 | December 8, 2006 12:01 |
