November 25, 2012, 08:12 |
Ansys problem in Parallel mode
Atthaphon
Rep Power: 14 |
I just install the Fluent(12.0.1) and after I open the Fluent at the first time in single mode it can use but after I open in parallel mode it have error
Host spawning Node 0 on machine "user-PC" (win64). You can press CTRL+C to stop the startup process! Unable to execute (null) \\USER-PC\C$\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\ multiport\mpi\win64\ms\bin\mpiexec.exe -np 2 -env PATH "\\USER-PC\C$\PROGRA~1\v120\fluent\ntbin\win64;\\USER-PC\C$\PROGRA~1\ANSYS~1\120\fluent\fluent12.0.16\ul tiport\mpi_wrapper\win64\mspi" "\\USER-PC\C$\PROGRA~1\ANSYS~~1\v120]fluent\fluent12.0.16\win64\2d_node\f1_mpi12016.exe " -mport 140.116.81.79:140.116.81.79.49715:0 nodde -mpiw msmpi -pic ethernet The system cannot find the file specified |
November 25, 2012, 18:39 |
Lucky
Rep Power: 66 |
check your firewall settings. It's likely blocking the mpi from executing. Maybe even antivurus software.
November 26, 2012, 02:31 |
Atthaphon
Rep Power: 14 |
thank but now I close the firewall but it have the same problem
November 26, 2012, 02:39 |
#4 | |
Lucky
Rep Power: 66 |
Also, try using another mpi. I think there is an intel, and pcmpi is usually supported by most platforms. There is also mpich/mpich2. The Ansys installation package also comes with an hp one I believe. |
November 26, 2012, 04:25 |
#5 | |
Atthaphon
Rep Power: 14 |
Parallel interDyMFoam cellLevel problem | tgvosk | OpenFOAM Running, Solving & CFD | 5 | February 19, 2014 02:24 |
PROBLEM in UDF on parallel fluent mode | rakadit | Fluent UDF and Scheme Programming | 0 | July 13, 2012 06:51 |
Parallel processing problem | newbie29 | OpenFOAM Running, Solving & CFD | 1 | June 22, 2012 04:23 |
Grid Check Fails in Parallel Processing Mode | askance | Main CFD Forum | 0 | October 20, 2010 10:11 |
DPM model in parallel batch mode | Prashanth | FLUENT | 2 | March 6, 2009 07:54 |
