Lifted laminar flames using Stiff Chemistry Solver
Old   November 28, 2012, 15:50
Exclamation Lifted laminar flames using Stiff Chemistry Solver
Javier Martinez
jmartrubio is on a distinguished road
I am new in this so please tell me if I haven't expained myself properly or you need more information.
I am using Fluent to simulate laminar lifted flames in 2D of a mixture methane-air. The domain is defined by a velocity inlet in which the composition of methane has a parabolic profile, two walls with a small tilt and an pressure outlet condition in the exit.
I resolve the cold flow to let the species mix and then activate the energy equation. I use Stiff Chemistry Solver with its default parameters, and the default under-relaxation factors also.
To ignite the mixture I patch two regions at high temperature. My problem is that the solution calculated depends on the initial regions set at high temperature. In all the cases the residuals go down to 1E-5 and the solution stays there after hundreds of thousands of iterations.
Do you know what could be the problem?
Thanks a lot for your help.
jmartrubio is offline   Reply With Quote
convergence in fluent, ignition sites, laminar flame, lifted flames, stiff chemistry solver
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Laminar solver? LES? or DNS? Ray Main CFD Forum 5 March 19, 2003 10:19
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
