Invicisd compressible flow over cylinder 2D
Like Tree1Likes
  • 1 Post By -mAx-
Old   December 1, 2012, 18:47
Default Invicisd compressible flow over cylinder 2D
wesam
wesam is on a distinguished road
hi
i have a problem in negative values of CD.
Images are shown for the solution process.
Please see the pic.
thank you
wesam is offline   Reply With Quote
Old   December 4, 2012, 03:12
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
your solution isn't converged (your second picture can prove it, since it is still oscillating)
disable the "check convergence" at 1e-3 and let iterate.
Just break the iterations once your cd has a constat value
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 4, 2012, 13:52
wesam
HI MAX
i have done what you said to me.but the result of CD is negative and it is impossible it must be positive.(aerodynamic basic).
where is the error.
thank you Mr.MAX
Old   December 5, 2012, 01:12
-mAx-'s Avatar
Maxime Perelli
I don't know...
check if the velocity and pressure distribution are ok
Check also the forces on your 2d-cylinder and compute manually your Cd
And also check if your axis are well defined, especially the one for Cd should be in same direction as fluid is flowing (it is the only explanation for negative value, since others are positive)
wesam likes this.
Old   December 10, 2012, 18:39
wesam
thank you MAX
please check your e_mail.
I am in trouble
you only one can help me.
thank you
Old   December 11, 2012, 01:31
-mAx-'s Avatar
Maxime Perelli
Originally Posted by wesam View Post
thank you MAX
I am in trouble
thank you
did you post a thread?
I don't have any email
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 11:34
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Producing a supersonic flow in a constant diameter cylinder clgs.1903 FLUENT 12 May 24, 2012 13:41
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 03:24
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
