Heat transfer problem at fluid-solid interface
Old   January 8, 2013, 22:31
Default Heat transfer problem at fluid-solid interface
kiwikiwi is on a distinguished road
Hi everyone,
I'm learning Fluent and I'm trying to model transient heat transfer from a metal cylinder to air by natural convection. I'm having trouble with interfaces and I'm not sure on the best approach, hopefully you can help. I am using Workbench 14.5, DesignModeler, ANSYS Meshing and of course Fluent. Here is what I have done.
1. Create a cylinder(solid) in DM
2. Create a box (fluid) which is larger than, and surrounds the cylinder
3. Boolean subtract of the cylinder from the box whilst preserving the tool body (the cylinder)
4.Created 3 named selections; cylinder, env, hotface. env represents the environment which is air and hotface is one end of the cylinder which will have a heat flux applied to it.
5. I mesh this using the Workbech Meshing program using default settings, a contact region with 3 faces is detected
6. In Fluent, 3 wall boundary conditions are created; hotface, wall-cylinder and wall-env.
7. I apply gravity, incompressible-ideal-gas (as an air property) and a heatflux to hotface.
Result: there is heat transfer to the cylinder but none to the environment.
Ideas: I have changed the Zones 'wall-cylinder' and 'wall-environment' to interfaces, created a mesh interface using these and got convection happening. Fluent creates 3 walls and a single corresponding shadow wall when I do this. This seems a bit messy as when I create the mesh interface there are 3 faces for 'wall-cylinder' and 9 faces for 'wall-env' (3 from the cylinder and 6 from the box.
What is the best way to approach this problem?
Thanks in advance
kiwikiwi is offline   Reply With Quote
Old   January 14, 2013, 15:31
Alright so I figured out that a much simpler way is to form all bodies into a single part in DesignModeler and then coupled walls and shadow walls are created as there is a conformal mesh. Much easier!
Old   January 14, 2013, 17:12
Markat is on a distinguished road
You could also mesh only the fluid (do not preserve booleans tool body) an use a shell conduction approach to model conduction in the cylinder.
Markat is offline   Reply With Quote
Old   January 14, 2013, 17:13
This is really a best practice when you to mesh both fluid and solid
Old   January 14, 2013, 18:47
Many thanks for your advice Markat, so much to learn and sometimes the User's guide doesn't spell out the basic things like this.
Cheers!
fluid-solid, heat-transfer, interfaces
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 02:18
goddamnit: how to set up heat transfer from fluid to solid macfly FLUENT 7 June 16, 2012 11:50
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
