Pressure far field vs Velocity inlet/Pressure Outlet
Like Tree6Likes
  • 6 Post By Santos-Dumont
Old   January 29, 2013, 02:50
Default Pressure far field vs Velocity inlet/Pressure Outlet
Derek Kim
cocobi is on a distinguished road
I just wanna ask you what's the difference btw 'Pressure Far Field' and 'Velocity Inlet and Pressure Outlet' when setting up the model of 2D airfoil (here, tried NACA 0012).
I tried both of them and found the following trends.
For the Pressure Far Field set,
Cd and Cl have a periodic trend on their graph and it repeated.
For the other case,
Even though the result of the two dimensionless factors showed a good convergence, the converged values were too far from the experimental ones.
So, I am wondering what I should look at when setting up the model for the boundary conditions.
cocobi is offline   Reply With Quote
Old   January 29, 2013, 10:45
Charles
Santos-Dumont is on a distinguished road
It is pretty straightforward, you can easily find some things about that on the Fluent Theory Guide. Anyway the thing is that VelocityInlet/PressureOutlet are only used for incompressible cases only (velocity under Mach 0.3)
If you are compressible (this is usually set up by setting your material density to Ideal Gas and Viscosity to Sutherland) you shall use Pressure Far Field. You can use your entire boundary (i.e inlet, outlet and sides) and set it up as one single boundary in your meshing software, that saves time while setting up in Fluent.
So velocity inlet for incompressible, and pressure FF for compressible.
Santos-Dumont is offline   Reply With Quote
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
How to get the velocity field from the pressure field Hermano Main CFD Forum 2 November 29, 2011 08:32
Physical meaning of pressure in pressure eqn dontknow Main CFD Forum 2 August 30, 2010 10:12
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 15:33
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
