Cylindrical Pipe
Old   February 6, 2013, 09:01
Default Cylindrical Pipe
Ben
bf3g10 is on a distinguished road
I have modelled a cylindrical pipe on the order of microns to simulate a microfluidic, incompressible, isothermal flow as you would when you're first starting out with Fluent.
Naturally, a sensible way to analyse the velocity profile is via the Hagen-Poiseuille equation and I determined that with an inlet pressure of 1Pa and a pipe radius of 100 microns and length of 2mm, that the maximum velocity in the centre of the pipe should be roughly 3x10^-4 m/s.
After simulation, the maximum velocity appears to be 2.534x10^-2 m/s; which is roughly a 100 times faster!
I've double checked my boundary conditions and fluid properties (I should mention that it is simply water) and they appear to be okay. Inlet pressure set at 1Pa; outlet pressure at 0Pa; no-slip at walls; dynamic viscosity of water at 10^-3 Pas and density of 1000kg/m^3.
I've also tried mucking about with the solution methods, in particular between standard, linear and second order settings for pressure and momentum and they all appear to be giving the same results.
Presumably I must be missing something obvious. Any suggestions would be much appreciated.
bf3g10 is offline   Reply With Quote
Old   February 6, 2013, 09:51
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi! Can you post a picture of your grid and of the residuals?
Also: Did you try how sensitive the result is to changes in pressure drop?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   February 6, 2013, 09:53
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Two pressure boundary conditions are not the easiest setup to achieve convergence.
I would start out with velocity inlet and pressure outlet.
Set the inlet velocity to a value from which you would expect a pressure drop of 1Pa along the pipe length.
Now you can cross-check the actual pressure drop in your simulation with what you expected.
This is actually just the other way round than what you did, but I would trust the results from a velocity/pressure setup more in the first place.
BTW: What kind of mesh do you use? real 3D or 2d-axisymmetric?
flotus1 is offline   Reply With Quote
Old   February 6, 2013, 10:44
Philipp
And after you did what flotus said, you need to rerun the simulation with a correct profile for the velocity.
Old   February 6, 2013, 11:01
Ben
Thanks for getting back to me so soon!
Rodriguez:
Mesh and screenshot of residuals while calculation was taking place. The solution manages to converge within 909 iterations although the residuals where set under Monitors -->Residuals-->edit for the continuity and x,y,z velocity equations as 0.001 which were default. Could that perhaps be the reason? Residuals set too high?
flotus:
I haven't thought of doing it that way. I'll have a go and get back to you. And I've set up a 3d mesh: tetrahedrons and body sizing with element size of 1x10^-5m
Old   February 6, 2013, 11:42
flotus1's Avatar
Alex
The residuals definetly are too high for such a simple case.
With double precision, you can get them down to ~10^-15 with a high quality mesh. So I recommend more Iterations.
If this takes too long, switch to a 2D axisymmetric domain.
Did you cross-check the dimensions of your domain in fluent?
If you wanted micrometers but got millimeters, this could explain the higher velocity.
Old   February 6, 2013, 12:16
Ben
I've just tried setting a velocity inlet boundary condition instead of a pressure inlet to 3.125x10^-4 m/s which is what I would expect for a pressure drop of 1Pa along the length of the pipe. Of course, this is the maximum (centerline) velocity that I am inputting.
Having proceeded with the same steps towards the solution, it converged after 1 iteration! After looking at the velocity vector plot on CFD Post, it appears that the velocity magnitude is decreasing linearly just like the pressure in a pipe! This cannot be right for sure. Could you elaborate if this is what you meant?
The domain extent appears to be well within the physical limits of the model after checking the mesh with Fluent.
I have also tried decreasing the residual amount by a thousand to 10^-6 (with pressure inlet boundary condition). This yielded a slightly more promising maximum velocity value of 1.7x10^-2 m/s. A touch of an improvement to 2.5x10^-2 m/s.
I am now currently running a calculation under double precision with residuals of 10^-12.
edit: Okay, it appears that the equations had reached such a point that they were no longer converging at they level off so I stopped the calculation. The max velocity value appears to be the same as above - 1.7x10^-2 m/s
Old   February 6, 2013, 14:19
flotus1's Avatar
Alex
I guess you are still using the pressure boundary conditions.
The tet mesh might be responsible for the low velocity. With a pure tet mesh, there is no need to run double precision because the errors introduced by the poor mesh quality are several magnitudes higher than the roundoff errors.
I recommend a 2d axisymmetric domain once more.
Old   February 7, 2013, 11:12
Ben
Okay, I've modelled the pipe in two dimensions by following Cornell University's laminar pipe tutorial (https://confluence.cornell.edu/displ...+Specification) closely but with my own parameters.
I have tried both boundary condition methods (pressure inlet and velocity inlet) however with the pressure inlet case (inlet pressure = 1Pa, outlet pressure = 0Pa) I am still getting velocity values of 1.7x10^-2 m/s.
With the velocity inlet set as 3.125x10^-4 m/s, after solving and plotting a pressure contour, the pipe experiences a linear drop of 3.83x10^-2 Pa, not 1Pa which I was expecting.
Pressure and velocity values from Hagen-Poiseuille analysis appear to be mutually exclusive variables according to my simulations in Fluent...
Old   February 7, 2013, 14:30
Philipp
Im wondering if the differences come from the fact, that the analytical formulas describe a fully developed flow, whereas your simulations start (at the inlet) with some completely unphysical values. If you use a velocity inlet, you set a constant velocity along the complete radius. This is not how a pipe profile looks like. If you set a pressure inlet, you do the same wrong thing with the pressure. Now, why do you expect the results to hit the forumlas, when you don't use physical bcs?
Old   February 8, 2013, 03:51
Post
  #11
flotus1's Avatar
Alex
I just set up the case myself:
  • Pipe Radius: 10^-4 m
  • Pipe Length: 2*10-3 m
  • Dynamic viscosity: 1*10^-3 kg/(m s)
  • Pressure difference: 1 Pa
The result is a perfect parabola for the streamwise velocity throughout the pipe with a maximum of 1.25*10^-3 m/s.
I recommmend you check the analytic values again.
Old   February 8, 2013, 04:20
Philipp
How did you set up the inlet?
Old   February 8, 2013, 04:23
flotus1's Avatar
Alex
I tried both pressure inlet / pressure outlet and a periodic boundary condition with pressure difference. Same results.
Since pressure is (almost) constant in radial direction, the pressure boundary condition introduces only a small error source.
Old   February 8, 2013, 04:40
Philipp
Same results here... (3d case).
BTW: It took quite a time until the streamwise velocity started to converge. Is this due to the pressure-inlet + outlet?
Old   February 8, 2013, 05:19
flotus1's Avatar
Alex
Yes, that is what i meant in my initial post. Pressure/pressure setups converge slower than velocity/pressure.
With a velocity inlet, my setup reaches round-off accuracy after around 300 Iterations with single precision.
The pressure/pressure case takes around 800 Iterations.
Edit: I used a 2D axisymmetric domain.
Old   February 8, 2013, 05:22
Philipp
Also, equations from wikipedia give the same maximum velocity. As flotus already wrote: something strange happend in your calculation.
Old   February 8, 2013, 07:46
Ben
Okay, I've tried flotus' setup and achieved the same predictable incorrect results that I have always been getting. I used a 3d, half cylinder model with defined symmetry, inlet and outlet faces.
I have tried a pressure/pressure bc setup with 1Pa inlet and 0Pa outlet and achieved this velocity vector plot (image attached).
What am I doing different to you guys?
I guess I could try considering entrance effects as Rodriguez has suggested and adjust the physical model accordingly...
Old   February 8, 2013, 08:02
Talking
  #18
Philipp
Hear ye! This is an error that only appears when you at least double check your fluid properties. When you want to use a certain fluid be sure you actually switched it on in Fluent!
bf3g10 please go to Solution Setup->Cell Zone Conditions->'your fluid'->Edit...->Material Name
and change it from air to water.
Old   February 8, 2013, 08:13
Ben
Oh my goodness. So so embarrassing! Such a schoolboy error!
I've been sat here facepalming the past 5 minutes.
Thanks so much Rodriguez and flotus for being patient with me!
Old   February 8, 2013, 08:19
Philipp
I did that several times. One of the good old-fashioned mistakes
Also one of the nice errors is to mesh in ICEM and forget to scale the mesh to mm...
Nu values come up too high for cylindrical pipe turbulent flow Onur10 FLUENT 7 February 21, 2016 12:59
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 03:37
Using Local Cylindrical Coordinates for Pipe in CFD-Post drankinmacup ANSYS 0 July 6, 2011 16:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
