Eulerian model with DDPM
Old   February 20, 2013, 04:20
Default Eulerian model with DDPM
Luca Pirani
Lucaaa is on a distinguished road
Hello to all,
first of all I apologize for my English. Let me explain my problem. I'm trying to simulate with FLUENT a fluid bed reactor. I used the Eulerian-Eulerian multiphase model and thus far there have been no problems. Now, however, I was interested in assessing the trajectories of the particles inside the reactor, and then use the DPM model. In particular the guide I read that you can use the Eulerian model including the DDPM. when I go to set up my problem with these parameters, launch the simulation and immediately finds a divergence. How can I simulate this my model? I hope I was clear in explaining. I also tried to do the following:
-launch the simulation without introducing any particle so as to have a converged solution;
-insert the particle inside the reactor by selecting the DPM menu templates.
is correct? I thank you in advance for your answer.
Luca
Lucaaa is offline   Reply With Quote
Old   February 20, 2013, 08:53
Default hi
shoeb khan
shk12345 is on a distinguished road
The problem with DDPM model is that it always always diverges.
I have tried it a lot but always it diverges.
But according you one theory you have to first solve DPM model and then use the data from there to put in DDPM model.
U have to interpolate flow and particle trajctories from DPM and put in DDPM.
Tell me if it works.
Regards
shk
shk12345 is offline   Reply With Quote
Old   February 20, 2013, 08:56
Luca Pirani
thanks for the reply. I'm not sure how, but now it is simulating and seems to be fine. soon as I finish and let you know if I try with the method that you told me. Thank you again for your response
Luca
question about eulerian model for packed bed rone FLUENT 2 July 19, 2007 20:58
Mass and het transfer using eulerian model Pablo FLUENT 0 February 16, 2007 08:36
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 06:17
Strain Rate in eulerian model galeazzo FLUENT 0 January 25, 2005 07:52
