STANDARD WALL FUNCTIONS vs ENHANCED WALL TREATMENT
Old   February 22, 2013, 13:09
Default STANDARD WALL FUNCTIONS vs ENHANCED WALL TREATMENT
Roby_1986 is on a distinguished road
Hi everybody,
I'm simulating with fluent the natural ventilation in a building, so I've realized a mesh of a cubic building with a window, which is surrounded by a parallelepiped representing the external air. I've had to refine the mesh in some zones, as those close to the building walls and to the parallelepiped basis. The mesh is that of the attached image.
I've a doubt about the near-wall treatment. First I've set k-epsilon RNG with standard wall function. Setting the Yplus of the building walls and the basis of the parallelepiped (which is considered as a rough wall) I've obtained Y+ include between about zero and a 700. Now, I don't know how to proceed, becouse I should coarsen the mesh in those zones where Y+ are less than 30 and refine the mesh whare Y+ are more than 300. Is it right?
I know that Fluent can just refine the mesh and not coarsen it. So, what can I do?
Thanks a lot.
Bests
Roby_1986 is offline   Reply With Quote
Old   February 22, 2013, 18:31
david
davidwilcox is on a distinguished road
I think you should refine the y plus in the near wall region. The manual in fluent says that too fine a y plus value for a standard wall function can deteriorate your results. They suggested a y plus value of 11.13 ( i think). That should fall in the log region in the law of the wall.
The way i would adapt my meshes in fluent is thru this way ( in the near wall region). Adapt> Yplus> specify value. Run simulation and check again.
Then i would adapt regions of high velocity gradients ( or shear layer)
Hope this helps!
davidwilcox is offline   Reply With Quote
Old   February 23, 2013, 02:33
cfd seeker is on a distinguished road
Originally Posted by Roby_1986 View Post
Hi everybody,
Thanks a lot.
Bests
Use Scaleable Wall Funcitions aproach. Do a quick google search or consult Fluent's theory guide, you will learn how to activate them. Actually they prevent wall y+ to go below 30 in areas of high refinement.
cfd seeker is offline   Reply With Quote
Old   February 23, 2013, 03:29
Thanks for the replies.
Sincerely, I have a doubt. I'm studying the natural ventilation in a cubic building, through the presence of a huge parallelepiped of air surrounding it.
Now, where I've to do the control of the Y+ ?
As I said, I set the basis of my parallelepiped as a rough wall (representing the ground) and the walls of the cubic building (both internal and external) as smooth walls.
The Y+ control has to be done just for confined flow, so just for the internal walls of my building, or for all the walls of the model?
Thanks a lot
Bests
Old   February 23, 2013, 14:30
François Grégoire
macfly is on a distinguished road
Fluent can't coarsen mesh more than its initial size. Suppose you start with a mesh, refine it in Fluent (Adapt => ...), then you can coarsen it back to its initial size, not bigger.
That said, you could start with a coarse mesh, this way you should get rid of the low y+ regions. Then you can refine the mesh in the regions where the y+ values are large. The disadvantage is that mesh refinement is costly: A hexahedron is split into 8 hexahedra and a tetrahedron is split into 8 tetrahedra.
macfly is offline   Reply With Quote
Old   February 25, 2013, 12:15
Sheng
micro11sl is on a distinguished road
Just to remind that caution is needed when modeling surface roughness with wall functions(no matter standard or enhanced). You may have mesh restrictions. Consult the chapter of boundary condition in the user's guide for some information.
micro11sl is offline   Reply With Quote
Old   October 23, 2017, 08:28
Default hi
yun
gush is on a distinguished road
hi everyone!
it is generally explained that std wall function is best for y+>30 and enhanced wall treatment (EWT) for y+=1.
i am modeling the airflow in a very simple room now, y+ value is around 4. i decreased it to y+=1. but in any case (y+=4 or 1) standart wall function gives the best suitable velocity results with experimental data. EWT results are very different than "standart wall function" selection in any Y+ value
how can that be? i checked the literature which validated the same case for boundary conditions etc. but found nothing!
thx!
gush is offline   Reply With Quote
y plus and standard wall functions spk FLUENT 12 January 22, 2018 17:30
Enhanced Wall Treatment - Thermal Effects Brian Tang FLUENT 1 November 5, 2015 23:59
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
standard wall functions Irshad22 Main CFD Forum 0 December 20, 2010 06:11
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
