March 18, 2013, 16:54 |
Pressure Coefficient around cylinder
Steve Mcharg
Guys,
Doing a simple study to compare the Cp values to theta from a published paper. I have used the same domain size/physical model/similar grid resolution/material and boundary conditions, however I am not getting the same value for Cp to theta. Basically at the stagnation point (0 Degrees) I am getting a value of nearer 2... where experimental data, and the published paper suggest it should be 1. I read somewhere that it may be an issue with the domain size. Any thoughts? Cheers |
March 18, 2013, 19:17 |
Stuart Buckingham
Rep Power: 26 |
Pressure Coefficient greater than 1! You're breaking the laws of physics!
Set your reference values to something appropriate and try again. Stu |
March 19, 2013, 15:59 |
Steve Mcharg
I know.. crazy eh!
Okay thanks Stu, I think my depth/length reference values may be incorrect. I did manage to improve them slightly with a higher order numerical scheme, but still not right. Cheers |
March 24, 2013, 08:56 |
Steve Mcharg
Actually.. do you know what I should use in my reference values for this type of domain (in terms of length, width, depth)? For the length I think I may have references the Cylinder Dia...
Pressure coefficient | Giuseppe | FLUENT | 2 | July 26, 2015 03:19 |
Coefficient DRAG and LIFT - Cylinder 3D | Jwolf | CFX | 11 | February 4, 2010 05:08 |
Pressure Coefficient Viscous Coefficient | gunposer | FLUENT | 0 | June 15, 2009 07:10 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 04:15 |
