Warning: boundary Mach number exceeds maximum limit on pressure-outlet
Old   March 20, 2013, 10:05
Question How to avoid reversed flow in ** faces on pressure outlet ***??
Tarantino
Tarantino is on a distinguished road
Ciao!
I have ran a case in HVAC system with multi outlets. I got the warning "reversed flow in *** faces on pressure outlet" in two outlets. the residuals are straight horizontal and the didn't fall below 1e-1. So the results are not converged. How can I fix the problem to got a converge solution? I am wonder if this back flow is one of the reason that I cannot got converge or not? How can I avoid Back-flow? I refine the mesh, but still the same problem.
Ps: inlet set as mass flow inlet, outlets are set as outlet-vent or pressure outlet.
Thanks.
Tarantino is offline   Reply With Quote
Old   March 22, 2013, 21:30
Tarantino
Hello!
Please, give me any suggestion to avid back flow, I stuck in this situation.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
