Turbine simulation
Old   March 21, 2013, 01:17
Default Turbine simulation
Ivan Telnov
Gerim55 is on a distinguished road
Hi
I am trying to simulate a simple hydroturbine (2D) and I have some basic questions about it:
1) In this case turbine rotated by water and i don't know even approximately turbine's rate of rotation. So first goal of my simulation is to define it. From forum i know that there are few ways to solve such problem but i've not found any tutorials or help topic or some recomendations. Can somebody help me, maybe by posting links or etc?
2 ) Is it correct, when i want to define turbine's rate of rotation in the first simulation and then simulated a process with fixed number of revolution of turbine?
look forward to your help!
Gerim55 is offline   Reply With Quote
Old   March 21, 2013, 04:26
Thiagu
jthiakz is on a distinguished road
Good Attempt, I appreciate your way thinking started from real physical aspect.
To can get an idea about CFD modeling of flow in compressor /turbine.
Pls check CFX Turotial-4. Flow in an Axial Rotor/Stator
jthiakz is offline   Reply With Quote
Old   March 21, 2013, 06:10
Ivan Telnov
Thanks for the reply!
how i know, using this tutorial we should specify a rate of rotation. But I don't know this parametre and my goal is to define it
Old   March 21, 2013, 06:28
OJ
oj.bulmer will become famous soon enough
Well, since it's a turbine, isn't its rotational speed something an effect, rather than a cause? How about simulating a transient simulation by defining water flow rate etc and letting the software find it out? It would be a motion simulation though, and hence tricky.
OJ
oj.bulmer is offline   Reply With Quote
Old   March 21, 2013, 06:39
Ivan Telnov
OJ
I think it's a right way! but i don't know how simulate such transient simulation...
Old   March 21, 2013, 07:19
Ivan Telnov
And if we use another way - assume a speed and work out the torque. Sweep over a range of speeds and find the point where torque equals the output load (c) ghorrocks -http://www.cfd-online.com/Forums/cfx/87150-wind-turbine-rotation-baldes.html
How find the point, where torque equals the output load?
Simulation of Wind Turbine with OpenFoam be_inspired OpenFOAM 52 September 6, 2018 10:33
Spatially and time varying inflow - turbine simulation Alex_S FLUENT 4 July 19, 2012 02:45
Verifying results for a wind turbine blade simulation in ANSYS CFX Joystix CFX 3 April 27, 2012 17:52
wind turbine simulation moca CFX 1 July 25, 2009 06:48
cfx turbine simulation mehrdadeng CFX 0 March 31, 2009 05:08
