Anyone ever result in a different inlet pressure after iteration?
Old   March 21, 2013, 15:28
Default Anyone ever result in a different inlet pressure after iteration?
Jing
serene6390 is on a distinguished road
Hi, I'm doing simulation of a compresible flow in a pipe with some bumps on the wall.
I set the boundary condition of inlet pressure to be 10MPa and outlet pressure 7.4MPa, but it's so wierd that after long time iteration and the result comes converged( residual lower than 10e-4), the xy plot of static pressure shows the inlet pressure is different from the boundary condition I set (about 9.2MPa).
Can anyone ever experienced that? Please help me. Thank you so much.
and by the way, anyone knows how to set the friction factor in a pipe?
Thanks again!
serene6390 is offline   Reply With Quote
Old   March 21, 2013, 23:01
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Thanks again!
Inlet static pressure is function of outlet static pressure. But inlet total pressure should remain the same.
Far is offline   Reply With Quote
Old   March 22, 2013, 05:34
Thiagu
jthiakz is on a distinguished road
You mean to say that you imposed only two pressure BC's and solver has adjusted the pressure at inlet.
# What is the massflow/velocity/ Temperature at inlet or outlet
# Any interface inbetween ?
jthiakz is offline   Reply With Quote
Old   March 23, 2013, 19:58
Jing
Yes, I set them Pressure inlet and Pressure outlet, the inlet temperature is 300K and the model is adiabatic, I didn't input the mass flow.
the model is just a pipe with a bump on the wall, I'm looking for the condition when the flow is choked. So I fixed the inlet pressure and modify the outlet pressure to check whether the flow is choked at the bump. Is there anything wrong with my operation? Thanks a lot for your help.
Old   March 23, 2013, 20:15
Jing
Thank you so much for your reply. I checked my model and the total pressure remain the same but outlet total pressure doesn't.
I'm quite confused. In my model, I set the inlet pressure and outlet pressure as boundary condition, why do they change at last? should I change it to be velocity inlet ? What's your advise if I want to fix the inlet pressure?
Thank you so much for any of your help!
Old   March 24, 2013, 03:32
Thiagu
You need to specify one total quantity at intet. If the pressure ratio is approx 1.8, you will be able to demonstrate choked flow. by the way where did you get this inlet pr values. is it a measured quantity or scaled model.
# operating pressure also plays a role to predcit velocity
Old   March 24, 2013, 14:43
Jing
Thank you very much for your concern. What I'm trying to do is to find the proper boundary condition for my model, there's a bump on the wall in the middle of the pipe, so the 1.8 ratio you mentioned is not suitable for my model. I did the 1D computation using Matlab and using the solution from Matlab as the boundary condition to run in the Fluent.
Do you have an idea how to make the inlet static pressure fixed as 10MPa?
Old   March 24, 2013, 14:52
Far
Sijal
What should be inlet total pressure? That has to be larger than static pressure !
To get inlet static pressure of 10 Mpa, vary outlet static pressure and see where you get the required static pressure at inlet.
Old   March 24, 2013, 15:38
Thiagu
how did you calculate the total quantities in mat lab.In any case u'll need total P or T or velocity or mass-flow.
If I don't any of this data. I'll impose assumed (higher than Ps inlet)total pressure inlet and static pressure outlet and monitor mass in ,mass out , Static Pressure (inlet,before the bump, after the bump). so based on the monitor plot, I'll adjust the Ptot inlet, till it matches with static,pressure of 10mpa. This way i can check is possible.
Pressure ratio 1.8 is applicable not from the inlet to outlet rather applicable from inlet to the local downstream pressure near the bump.
fluent, friction factor, inlet
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 12:41
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
