help is wanted in arrhenius constants units
Old   March 22, 2013, 12:19
Default help is wanted in arrhenius constants units
hossam ali
hossam_ali is on a distinguished road
i am working on combustion problem with cfd using lameiner finite rate and i am wondaring what is the units of arrhenius pre-exponent factor. in the fleuent help they mentioned it is consistant units but i can not understand
plz help , also does the units changed with reaction order in case it is second order or thired order
thank alot
hossam_ali is offline   Reply With Quote
Old   March 22, 2013, 15:03
François Grégoire
macfly is on a distinguished road
http://en.wikipedia.org/wiki/Arrhenius_equation
"The units of the pre-exponential factor are identical to those of the rate constant and will vary depending on the order of the reaction."
macfly is offline   Reply With Quote
Old   March 23, 2013, 04:26
Default thanks but i need more help
hossam ali
dear macfly thanks for ur response, i want to know the units of pre-exponent factor used in fluent for second and third order is it m3/mole or m3/kgmole
if u have example plz help and my email is hossam_ali_71@yahoo.com
fluent help just mentioeb it is consistant units and i understand this but should i put it in m3/mole or m3/kgmole
u can see the window of fluent in the next link
https://www.sharcnet.ca/Software/Flu...g/node1078.htm
thanks alot
Old   March 24, 2013, 11:30
François Grégoire
Maybe you can just initialize a simulation, plot the pre-exp factor somehow and check the units.
Old   March 24, 2013, 12:24
hossam ali
Maybe you can just run a simulation and check the units of the pre-exp factor in the postprocessing.
thanks again i will do it but i donot if this option in fluent
thanks
How are the integration constants for the JANAFthermo class derived? tomf OpenFOAM Running, Solving & CFD 2 May 15, 2015 07:47
chemical reaction problem Benoit FLUENT 2 March 14, 2013 14:56
units in OpenFOAM megacrout OpenFOAM 4 July 19, 2011 08:04
Mass transfer units in fluent nite_surfer FLUENT 0 July 12, 2007 12:51
Wanted buoyancy constants in k-epsilon model grig Main CFD Forum 1 February 5, 2000 18:21
