April 23, 2013, 06:22 |
determine rpm value of turbine
ruya
Rep Power: 13 |
hi friends.
I have a problem that how can determine value of turbine flow meter. Firstly I gave an arbitrary value to rotor such as 11 rad/s then I calulated torque with cfd- post but I don't know that I move on or how can ı compare torque and rpm that I gave. I want to help. Thanks. |
April 30, 2013, 12:39 |
ruya
Rep Power: 13 |
thanks but I haven't got experimental results. I change my procedure. I prefer that I obtain volumetric flow according to given rpm. but I have a problem because volumetric flow rate doesn't change according to value of rpm. This stiuation is impossible and rpm doesn't effect flow rate.
April 30, 2013, 19:19 |
Stuart Buckingham
Rep Power: 26 |
You have three variables in your simulation that you are trying to either control or evaluate: mass flow rate (or pressure ratio), turbine speed and load.
On a dyno, you would specify the MFR and load to get the resulting speed, however to do this in a CFD simulation requires a UDF to modify the rotational speed depending on the torque at the turbine axis. This is rather complicated and not recommended. An easier approach is to set the rotational speed and MFR then measure the resulting torque. Once you graph these results, you will get the same figure as if you had dyno tested the turbine. Stu |
determine rpm value of turbine | ruya | Main CFD Forum | 2 | April 26, 2013 04:48 |
turbine RPM in star-ccm+ | saleh alsubari | STAR-CCM+ | 1 | August 28, 2012 19:10 |
Wind Turbine RPM in CFD | Shamoon Jamshed | Main CFD Forum | 4 | February 13, 2012 12:42 |
OpenFoam 1.6-ext - RPM build errors | preibie | OpenFOAM | 12 | September 8, 2011 03:12 |
RPM vs time for a turbine | johnny | FLUENT | 0 | November 10, 2005 04:00 |
