Discontinuity due to Interior edge !!!
Old   April 26, 2013, 22:19
Default Discontinuity due to Interior edge !!!
Babak
Babak.Mazhari is on a distinguished road
Hi guys,
I'm solving the energy equation on two solid zones with the same physical properties separated by an interior type edge. But, I'm observing a small but noticeable discontinuity in the solution at the interior edge which is obviously not correct !!! I'm not using a very fine mesh but I'm confused why is it happening ?
If I don't use an edge, the discontinuity will disappear, so it is because of the edge !! Does the interior edge play any role in the computations ?
Babak.Mazhari is offline   Reply With Quote
div(grad) not equal to laplacian close to a discontinuity gtg258f OpenFOAM 10 December 6, 2012 05:58
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 12:00
discontinuity of solution due to interfaces ? T.D. OpenFOAM Running, Solving & CFD 4 December 20, 2010 09:42
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
Stepwise Discontinuity problem Alan Kang Main CFD Forum 1 February 22, 2000 23:46
