Get a variable at each time-step
Old   April 30, 2013, 10:44
Default Get a variable at each time-step
Parisa
Parisa_Khiabani is on a distinguished road
Hello everyone,
I would like to get the mass fraction of a component in the mixture at each time-step and use that in the journal file that I have written.
In fact, I want to get mass fraction of component X, inside the journal file like physical time, time-step size etc.
The problem is that since mass fraction is a post-processing variable, I cannot use getvar in journal file.
So, I don't know how to get this variable at each time-step.
Would you please guide me if you are familiar with that?
Thanks,
Parisa
Parisa_Khiabani is offline   Reply With Quote
Old   April 1, 2014, 15:47
Smile
vlg
villager is on a distinguished road
Assuming you have boundary zone "outflow1" and you want to know mass fraction of X, the following commands should be added to your jou file:
/report/surface-integrals/area-weighted-avg/
outflow1
X
y
X_mass_fractions.srp
y
the last y to append data, not to overwrite. The previous y - write to file - yes. Exchange y for your substance, e.g. H2O.
Probably, you can use
plot/solution
plot/solution-set/plot-to-file
(try to make it work manually, start FLUENT in terminal mode and train yourself)
villager is offline   Reply With Quote
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Time step, Number of time step, Maxximum Iterations per time step sandisk FLUENT 0 July 18, 2011 02:57
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
