May 12, 2013, 02:29 |
DPM particle tracking
sajeesh
Rep Power: 13 |
Hi
I read DPM particle tracking will consider the particle as a point.so my question is whether this model is sufficient to track the particle which driven through the fluid domain by drag force only.. whether it will give the proper velocity change happened to the particle when dragging by the fluid. I need to calculate the what will be the steady state velocity of the particle even if the particle is introduced in the fluid domain at velocty of zero velocity.will acheive the maximum velocity of fluid or the more than the maximum velocity of the fluid. thanks in advance sajeesh |
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message | peteryuan | OpenFOAM Installation | 6 | August 18, 2013 18:00 |
DPM particle traCKING | sajeesh | FLUENT | 1 | April 27, 2013 23:12 |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 12:03 |
DPM particle tracking | parisa- | Main CFD Forum | 2 | June 15, 2011 05:12 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
