Valve profile for an internal combustion engine |
May 16, 2013, 10:20 |
Omar
Rep Power: 13 |
I'm currently working on the Tutorial 12. Cold Flow Simulation Inside an SI Engine. I don't understand the valve.prof file. when i open it with text editor i have this: ////////////////////////////////////////////////////////////////////////////////// ((ex-valve point 141 1) (angle 1.119000e+02 1.120000e+02 1.140000e+02 1.160000e+02 1.180000e+02 1.200000e+02 1.220000e+02 1.240000e+02 1.260000e+02 1.280000e+02 1.300000e+02 1.320000e+02 1.340000e+02 1.360000e+02 1.380000e+02 1.400000e+02 1.420000e+02 1.440000e+02 1.460000e+02 1.480000e+02 1.500000e+02 1.520000e+02 1.540000e+02 1.560000e+02 1.580000e+02 1.600000e+02 1.620000e+02 1.640000e+02 1.660000e+02 1.680000e+02 1.700000e+02 1.720000e+02 1.740000e+02 1.760000e+02 1.780000e+02 1.800000e+02 1.820000e+02 1.840000e+02 1.860000e+02 1.880000e+02 1.900000e+02 1.920000e+02 1.940000e+02 ///////////////////////////////////////////////////////////////////////////////// If somebody can tell me what this file is for ? and what's the meaning of all the angles ? Thanks. Omar |
May 24, 2013, 08:23 |
Zacarias Carral
Rep Power: 13 |
Where did you find that tutorial? I am interested on that.
May 24, 2013, 10:06 |
#3 | ||
OJ
Rep Power: 20 |
Files: http://www.mediafire.com/?6788sus7dcnd2 OJ |
May 24, 2013, 11:03 |
#4 | |
jemy akvianto
Rep Power: 13 |
May 25, 2013, 07:20 |
Omar
Rep Power: 13 |
Thanks for your answer,
do you have any tutorial on the 3D internale combustion engine or adiabatic compression ? this will be realy helpfull for me. |
August 7, 2015, 10:19 |
Can you Please share me engine geometry as i failed in ciinstructing valve error Mess
Chotai Nikhil
Rep Power: 10 |
I hope one of get success in cold flow simulation so request to share engine model because i am getting error message in valve sheat i tied a lot for same. My email ID is nikhilchotai@gmail.com |
August 21, 2015, 09:58 |
Vijay Bodkhe
Sir, Can you give information about how valve.prof is created for any engines valve profile.I want to create valve lift profile of TV1 engine.So I can use it in Ansys Simulation of IC Engine.
Thanks in advance. |
April 5, 2016, 20:59 |
Repost tutorail link
#9 |
Ripusudan Agrawal
Can you please repost that tutorial link, the one you provided is not working. Thanks
November 17, 2017, 09:56 |
How can I patch my valve profile in Linux ansys
#10 |
BIBU B
Rep Power: 8 |
Linux OS ansys running
When I patching valve.prof. it shows ,not compatible for Linux so what change I need to do ? |
December 6, 2018, 08:14 |
Downloading valve profile and geometry
#11 |
AH
Rep Power: 13 |
Have downloaded student version for fluent ic. Can't find where to download files referred to in title bar. Can anyone explain how where to go, thanks in advance.
Working this tutorial:- Chapter 15: Tutorial: Solving a Cold Flow Simulation Called for in this tutorial subsection: - 15.1. Preparation 1. Copy the files (demo_eng.x_t and lift.prof) to your working folder. To access tutorials and their input files on the ANSYS Customer Portal, go to http://support.an- sys.com/training. 2. Start Workbench. |
January 11, 2019, 00:10 |
#12 |
Kanaka Raju
we are doing an acadamic project on Ic engine cold flow analysis in cfd. How we write a valve lift profile?
July 24, 2019, 12:44 |
#13 |
AH
Rep Power: 13 |
I have followed a tutorial on utube. Got pressure changes in cylinder, but couldn't see movement of piston wall. Is it a post processing issue?
July 24, 2019, 12:47 |
#14 |
AH
Rep Power: 13 |
April 21, 2023, 05:35 |
#15 | |
Peace Akinlolu
Rep Power: 3 |
engine, fluent, internal combustion, profile, valve |
Fluent 2d 4 Valve SI Engine | Cola1988 | FLUENT | 0 | January 27, 2012 17:03 |
Proper BCs for internal fan | serezhkin | CFX | 3 | July 28, 2010 10:04 |
Can I simulate the internal combustion engine with OF? | fuvictor | OpenFOAM | 0 | October 27, 2009 21:40 |
Help: IC engine fan design | Sigan | Main CFD Forum | 1 | May 24, 2005 18:40 |
CFD simulation in Internal Combustion Engine | Anne | Main CFD Forum | 17 | May 5, 2005 05:06 |
