June 23, 2013, 10:56 |
Simple gas dispersion help
Rep Power: 13 |
Hi all,
I am relatively new to CFD. I'm trying to validate a simple gas dispersion model in the presence of an obstacle. It is Thorney Island trial number 26. It is a transient based simulation. The gas is freon 12 (31.6% w/w) and nitrogen (68.4% w/w) and is released instantaneously 50m upwind from a small building. The gas is denser than air with relative density of 2.0. So I have enabled the species model and K-e standard model. I defined a log profile for the wind (Velocity Inlet) and ran a steady state with air only and converged. The wind speed is 1.9 m/s. The side and up boundaries are Symmetry and the outlet is set as Outflow. Then I patched the species to a cylindrical region, 50m upwind of the obstacle. I enabled gravity (-9.81 m/s^2) and enabled operating density (default). I ran the transient for 250 seconds with 1 second time step. I measured the concentration at the building (mol fraction of freon-12). The shape of the graph looks exactly like the experimental which is good but unfortunately the %v/v of Freon-12 is exactly 10 times less than the experimental. For example, the experimental peak is 2% at 50 s. Mine is 0.18% at 50 seconds. I can't understand what's wrong. Do I need to define any more boundary conditions? Edit: It appears that I have now discovered the source of my problem. The mass fraction of Freon I was patching was too low. I know that the total volume of gas released is 2000 m^3. Therefore based on the fact: Density Freon = 1305.8 kg/m3 Density N2 = 1.135 kg/m3 Total volume = 2000 m3 Required relative density = 2 So 1.135 (1-x) + 1305.8x = 2*1.225 This gives vol fraction. From there I can calculate the total mass and hence mass fraction. Although before I start the simulation, the highest density in the domain is 2 kg/m3 which is still less than the relative. How is fluent calculating the density? Last edited by masands; June 23, 2013 at 21:48. |
May 12, 2022, 05:28 |
Same Problem
Ramzan Nazir
Greetings,
I am modelling the same dispersion experiment as yours and facing the same problem. Can you please guide me through this. |
Gas Dispersion Simulation | Fluid Engineer | FLUENT | 3 | April 18, 2018 05:03 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Gas dispersion in air error message | redhoax | OpenFOAM Running, Solving & CFD | 27 | October 25, 2013 05:31 |
Inlet boundary condition for gas dispersion in low Re channel flow | vainilreb | OpenFOAM Pre-Processing | 0 | February 22, 2013 03:03 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
