how to implement a Real gas law in fluent?
Old   July 2, 2013, 04:03
Post how to implement a Real gas law in fluent?
NAD
NAD is on a distinguished road
Hi.
I’m simulating two-phase flow with combustion inside a closed volume. In fluent the density of the compressible gas phase is calculated by using “ideal gas law”. I want to use ‘’real gas law’’, for example Nobel-Abel law. But I don’t know how to implement this new law into fluent via UDF.
Does anyone have an idea how I can do this? </SPAN>
Regards,
NAD is offline   Reply With Quote
Old   July 2, 2013, 07:30
Yash Ganatra
yashganatra is on a distinguished road
Go to Materials, then from Density tab select Real Gas but i don't think Nobel Abel Law is there. There are other options.
If you want to stick to Nobel Abel Law, then you will have to write a user defined function. (UDF)
Yash
yashganatra is offline   Reply With Quote
Old   July 4, 2013, 02:24
NAD
Hi Yash,
thanks for your reply. Yes I want to use Nobel-Abel Law, and I can easily write an UDF for that. But the problem is in fluent if we use a Nobel-Abel Law instead of Ideal gas law, we should change a few other parameters such as the sound speed, the entropy and some Derivatives such as the partial derivative of density with respect to pressure at constant temperature.
So the density law and the sound speed will be incorporated through the material panel. But for the others parameters I didn't find a way to incorporate them into fluent!!!!
Regards,
Old   July 4, 2013, 03:14
Yash Ganatra
Just go through Define Property Macro in FLUENT UDF and see if such changes can be incorporated through UDF
Old   July 4, 2013, 03:16
Yash Ganatra
See DEFINE PROPERTY macro in UDF and check if such changes can be incorporated via a UDF. Could you kindly tell which problem are you working on?
Yash
Old   November 13, 2015, 17:28
navid
ndabir is on a distinguished road
Hi NAD,
Were you able to solve your problem? If so could you please tell me how did you implemented the real gas udf in Fluent?
ndabir is offline   Reply With Quote
compressiblity, ideal gas law, two-phase flow, udf
NOx UDF Abhishek Asthana FLUENT 5 October 12, 2016 07:24
view factor yoollooz Fluent UDF and Scheme Programming 0 March 1, 2013 00:44
UDF for Turbulent Viscosity Lourival Fluent UDF and Scheme Programming 3 October 13, 2012 03:09
0 or 0.0 in udf wlt_1985 FLUENT 5 June 29, 2011 16:27
Real Gas Mixture With Reactions Jake Cannon Main CFD Forum 0 January 16, 2007 11:46
