MPI problem with fluent
Old   July 4, 2013, 04:29
Default MPI problem with fluent
JEEE
alexsatan is on a distinguished road
Hi,there
I met some problems with running Fluent in Win7.
VOF and DPM model was used in the calculation. The fluent calculation will stop with the problem as follow>
MPI application rank 0 exited before mpi_finalize() with status -1073741819
The fl process could not be started
Is there anyone know what is the problem?
Thanks a lot!
alexsatan is offline   Reply With Quote
Old   July 7, 2013, 17:17
Christopher Hershey
Hershey is on a distinguished road
Please post some more information about when the error occurs and the problem set up.
Are you using a UDF?
Does the error occur as soon as you start Fluent or
Does the error occur when you start the simulation?
I had a similar issue like this once and it was because I incorrectly specified the compiler directives in my UDF.
Hershey is offline   Reply With Quote
Old   July 9, 2013, 04:56
Smile some details
JEEE
Hi, thanks for your consideration.
I used DPM and UDF model in the simulation. There is inlet-velocity boundary conditions in which *profile* method was used.
There was no errors when VOF and profile were used, and no errors when VOF and DPM were used. Errors Only come out when VOF, DPM and profile were combined.No UDF.
So I am thinking if there are some conflict between VOF, DPM and profile.But I can not find any useful info..
The errors are shown as attanchment:
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
Problems with FLUENT MPI on i7 2600K/P8P67 TaurusASV FLUENT 1 May 5, 2011 11:58
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Problem using parallel Fluent Gustavo FLUENT 0 June 27, 2004 23:12
