Boundary conditions - Heat transfer coefficient |
August 8, 2013, 09:10 |
Quentin
Rep Power: 12 |
I am working on modelling a double pipe heat exchanger in ANSYS fluent. For the outer wall of the exchanger I have modelled the wall as Convection in the thermal conditions. However I do not know what value to input in the "Heat transfer coefficient" field. Is this the Overall heat transfer coefficient? (i.e. does this take into account the thermal resistance of the convection to the wall, conduction through the wall and convection away from the wall to outer environment?) Or... is this simply the material's heat transfer coefficient? Any help is much appreciated. Thanks in advance |
August 9, 2013, 03:31 |
Alex
Rep Power: 47 |
The heat transfer coefficient in this field represents the convection away from the wall to the environment.
The conductive heat transfer through the wall is determined by the "wall thickness" (0.00175m in your case) and the material of the wall (polypropylene in your case). The convective heat transfer to the wall is a result of your simulation (I guess you are actually simulating the flow inside the pipe) |
August 9, 2013, 11:08 |
Quentin
Rep Power: 12 |
Thank you flotus
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 06:29 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
