porous media formulation
Old   August 16, 2013, 00:45
Default porous media formulation
tom jolly
teejey is on a distinguished road
hi,
I'm trying to model the flow inside a flat heat pipe,with water as working fluid, which consists of vapour core, a wick structure and an outer casing. initially i tried to model the flow inside vapour core and wick structure separately, but couldnt get the proper fluid distribution. the error was with specifying the pressure at the boundaries.
As am new to FLUENT, i couldnt develop the problem correctly for formulating the wick structure.
can anyone help me regarding how to specify the pressure @ boundaries for the vapour core alone and how to develop the problem in porous media..i tried reading the tutorial for porous media but was not able to obtain a correct picture.
hope to hear from you soon.
Thanks in advance
teejey is offline   Reply With Quote
Old   April 8, 2020, 04:56
Wyj
李正
Wyj is on a distinguished road
Originally Posted by teejey View Post
hi,
Thanks in advance
Dear tom , have you solved the problem
Wyj is offline   Reply With Quote
fluent 14, heat pipe, porous media, pressure boundaries
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
relative velocity resistance formulation, porous media arminheidari FLUENT 0 January 7, 2013 04:02
physical velocity formulation and porous media KLG FLUENT 2 June 10, 2003 10:14
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
