Natural Convection - Problem in achieving converged solution |
August 21, 2013, 23:05 |
Rep Power: 12 |
Hi People,
I have some enquries regarding natural convection simulation for my final year project. Basically, I am now doing a validation study by making comparison with the experimental study using my computational study. This experimental study will have a simple enclosed cylindrical duct with a temperature difference at both sides of the duct. A high temperature and a low temperature will be fixed at both ends of the ducts. The circumferential face will be assigned to be adiabatic (assuming face is well insulated). This will induce a natural convection within the duct. I am using ANSYS Workbench to generate my mesh only for the fluid domain. I am using 'inflation' method to create the boundary layer mesh. Thus, I am using the y+ value in the order of 1 to calculate the y value as I will be using the first layer thickness in the ANSYS Mesh with 20 layers and the growth rate of 1.2. For the rest of the mesh, I am using the tetra mesh with the element size of 10mm. As for the boundary condition, I am setting a fixed temperature at both ends (82 and 14 degree celsius) of the duct and the circumferential face as adiabatic. Fluid used will be distilled water with the operating temperature of 25 degree celsius. Since the temperature difference at both ends is not large, I am applying Bossinesq theory to calculate the buoyancy effect, thus the operating density need not be stated. SIMPLE Scheme and First order Scheme are used initially achieve convergence first. Since the boundary condition will lead to turbulent natural convection, it is adviced from the following link to reduce the order of Ra number by 2 first. http://aerojet.engr.ucdavis.edu/flue...ug/node572.htm I did not apply turbulence model for the first run since the Ra number is in the order of magnitude of 10e7. I started with this but I could not get the a converge solution especially for continuity. I have tried to toggle around with the relaxation factors by reducing the body force and momentum and when it gets converged, i slowly increase the relaxation value again. I still have difficulty getting the solution converged. Do you have any advice for this? Thank you so much for your time and advice. |
August 28, 2013, 10:45 |
Yogesh Patil
Did you try using 0.7 for pressure and 0.3 for momentum?
August 28, 2013, 10:51 |
Rep Power: 12 |
Thank you for your reply!
I have not tried that. I only reduce the default value by 0.1 for each controls. May I know the reason for using 0.7 for pressure and 0.3 for momentum? |
Flow is not converging in natural convection problem of boussinesq model for air | rahulsharma | FLUENT | 4 | December 2, 2020 21:07 |
solution is converged but a problem | flow_CH | FLUENT | 9 | June 2, 2020 09:34 |
Problem with natural convection | claudia.h | FLUENT | 2 | July 3, 2012 03:10 |
boundary conditions for Natural Convection problem | Nav | CFX | 13 | June 6, 2011 07:37 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
